R55 Clutch is done.
Clutch is done.
Hello all. The clutch on my 2014 base clubman, with 94,000 miles, has gone south. The repair shop will charge $4500.00 to replace it. I know it is a big job. Does anyone know the price ranges for this repair? I just might trash the car, and move onto a more reliable brand.
Thank you.
Thank you.
$4500 is about twice as much as it should cost.
If you purchase the parts on your own, should only cost ~$1100 for a new clutch kit and flywheel. There are some other smaller parts in there that should be replaced when changing the clutch too. A decent independent shop should only charge about ~$1000-1200 for labor. If the rest of the car is still in good shape, might want to shop around.
And is the flywheel a replacement item on a clutch job? that seems a bit over the top.
Yikes! Although I don't have a manual I'm shocked that a clutch, cover and release bearing/slave (are they one unit) would cost that much. when I did the one in my Saab I think I paid something like $350 for the whole shebang.
yea, I get the labor cost. The clutch job on the FWD Saab 9-5 is no walk in the park either. And the slave/release bearing is a single unit (hydraulic) so it's wise to replace that while you're in there). But the parts cost of $1100 for a clutch kit and related parts? like I said I paid something like $350 for the clutch, cover, slave/release and a plastic alignment shaft.
An OEM clutch kit and flywheel will cost ~$1800 just in parts cost.
By comparison, a performance kit from ClutchMasters (clutch, pressure plate, bearing, and flywheel) will run ~$1100.
Prices above do not include clutch fork, pivot pin, seals, etc.
mickeymo
12
Aug 26, 2014 07:47 PM
