High pitched squeal from fan????
Old Dec 23, 2004 | 06:32 PM
J-Didi's Avatar
J-Didi
Help! My 04 MC is making a high pitched squeal at idle. It comes and goes. Sounds like a fan motor??? I noticed it happens when the cooling fan comes on.
I also hear what sounds like water/liquid gurgling. Could this be boiling coolant?
Opinions please. Oh and Merry Christmas!
Old Dec 23, 2004 | 07:24 PM
JoeDentist's Avatar
JoeDentist
A high pitched whine could indeed be your cooling fan. They seem to have a tendency to score their bearings. Should be easy to check in an MC - open the hood and you should be able to see when the fan starts up. If that is when it whines, a replacement fan should do the job. Even with the fan working, gurgling noises are not unusual - the water pump stops when the engine stops, so if the head and block are hot when you turn the engine off, it can actually boil water in the block. A lot of people recommend letting the engine cool at idle for a few minutes before turning the engine off.
Old Dec 23, 2004 | 09:47 PM
J-Didi's Avatar
J-Didi
Thanks for the feedback.
Old Dec 24, 2004 | 11:37 AM
Hammer's Avatar
Hammer
I had a loud whine in my '05 MCS. After 3 trips back to the service dept it eventually ended up being the alternator. However, the whine only occurred under power - you really couldn't hear it at idle, but it increased with RPM increase. From your description it doesn't sound like the same thing.
Good luck!
lweaver
Sep 17, 2024 08:22 AM
Casrio
Apr 20, 2021 01:52 AM
Sep 3, 2015 10:29 AM
Ntety
Sep 2, 2015 08:39 PM
Sep 2, 2015 11:15 AM
