R56 Persistent codes 672 - 354 - 050
Old Jul 6, 2020 | 04:20 PM
Kosmosnautes's Avatar
Kosmosnautes
Howdy everyone,
I´ve been having some issues with my car.
It´s a Mini Cooper Salt 2011 Automatic
R56 Model N16 Last serial digits BT201040
Been coming back & forth with 2 mechanics and the agency with no luck.
It all started one day where the car shut down and showed the code CC-ID 672 i restarted the car and had no issues for almost a week.
Then it started to happen more often, took it to my mechanic and changed the Break Pads along with some deep cleaning. Had no issues for about 3 weeks. After that time, i had a hit & run accident : The guy ripped the front fascia along with the right headlight & fog light. The car was for more than a month in repair.
When i turned on the car, it would make a CLICK sound on the passengers side , then the code CC-ID 672, 354 and 050 . It triggers faster whenever i use the electric windows (and internal lights would fade too) then the car shuts down when running.
Sometimes it would loose power for a second and then recovers .
The mechanic restarted the car´s computer, cleaned the codes, changed the break pads, the break sensors and replaced fuses. After this, the error persists but it takes more time for them to show (about a 10 min use)
Old Jul 7, 2020 | 07:41 AM
giorgos's Avatar
giorgos
Welcome to the forum!
Did your mechanic check the battery? Did he try starting the car and running it with the battery hooked up to donor car's battery (also with running engine)?
Old Jul 7, 2020 | 05:04 PM
Kosmosnautes
Thank you!
The battery was replaced on December 19 , the older one died. All lights seems to work fine except when i lower the windows.
They ran a diagnose on the battery and it´s good.
impakt
Jul 23, 2021 05:11 PM
ColoCoug
Sep 8, 2017 03:12 PM
BennyF
R60/R61 Stock Problems/Issues
Jul 31, 2015 02:05 PM
a2oc
May 8, 2015 03:28 PM
usafdrew
Apr 14, 2013 11:30 AM
