FS:: M7 Adjustable coil overs
SOLD M7 Adjustable coil overs
Category: Suspension
Price: $350
Location (Region): NorthWest
these have adjustable rate struts (small dial on bottom of fronts, and larger dial wheel between the lower mounting bolt - see the pictures).
these do not include the tool to adjust the perches (not included when I bought them).
the guy I bought them from said he used them for one season of auto-cross, and then bought a different set. I’m guessing that was not actually the case as all the dust boots are torn.
Manufacturer's Description
When we started engineering the M7 Coilovers, there were specific design issues that we wanted to address. Our other goal was to build an excellent shock at a very fair price point ... and we believe we've done just that and more.Issue #1: Dynamic ride and handling capabilities with exceptional compression and rebound control.
Issue #2: ***** that are easy to adjust without removing the coilover from the suspension.
Issue #3: Class-leading performance at an affordable price.
The M7 Coilover System is a mono-tube, nitrogen gas pressure shock. The coilovers feature 15-position compression and rebound "click" adjustments, plus height adjustable settings. Addressing our design issues, we made sure both the front and rear adjustment ***** are extremely easy to access, plus the adjustments are easy to feel with the "clicks" so you know exactly what's going on.
Spring rates were chosen to give outstanding drivability both on and off the track -- 240 lbs. front and 280 lbs. rear.
These will fit R55-R59 models of Mini Cooper
SOLD
Last edited by Absolutjh22; Jun 25, 2020 at 12:32 PM. Reason: SOLD, removing photos
