R50/53 R53 P0304 code
Old Jun 3, 2020 | 06:30 PM
ninjatuna's Avatar
ninjatuna
R53 P0304 code
Hello, I have a 2005 r53 with about 120k miles and 17% SC pulley reduction. Recently purchased it and it gave me a lean code that was resolved with a new fuel filter, immediately after starting it for the first time with new filter it threw the p0304 code. I pulled the spark plugs and noticed the cylinder 4 plug had slightly larger gap so I swapped them all with the same brand NGK iridium spark plugs. After putting new plugs in I unplugged battery to clear ECU but code is still there. I believe it is stock coil pack but has aftermarket leads and 1 step colder plugs.
Also worth mentioning is the P0108 code that I am waiting to have system smoke tested. Replaced TMAP sensor with another OEM but noticed fuel smell on original sensor.
Old Jun 3, 2020 | 06:59 PM
madcanvis's Avatar
madcanvis
I’ve got an 05 also with 17% under pulley and 110k miles and prob will need a fuel filter soon so I’m subscribing.
Old Jun 4, 2020 | 04:15 AM
Apexlate's Avatar
Apexlate
P0108 is commonly associated with crank pulley problems. I'm assuming your crank pulley is relatively new?
Old Jun 4, 2020 | 10:29 AM
ninjatuna's Avatar
ninjatuna
I believe it is stock crank pulley
leftfield6
Jul 15, 2019 06:49 AM
scottt
Mar 5, 2019 11:56 AM
cejak
Dec 13, 2014 07:45 PM
Cliff_2004
Aug 21, 2014 09:31 PM
valvashon
Jun 12, 2013 01:54 PM
