Water in fuse box help! R60
Old May 29, 2020 | 04:34 PM
Hawaiidabest's Avatar
Hawaiidabest
Hello everyone! I recently was curious and opened the fuse door located in the passenger footwell. I saw a trail of white dust coming from above down onto the fuses. I realized it was water residue and had a MINI heart attack lol I don’t have a sunroof so it can’t be that. The only 2 things I can think of is the battery cover had a tab broken. (Maybe water went tru the seal on that)? I also went thru a car wash like the ones that spray underneath. I went really slow to try and get my monies worth, maybe it was too high of pressure? I don’t know. Have any of you had this happen? What other components could I look at? I also remember that after the car wash the radio turned on by it self so idk but no other problems
Old Jun 4, 2020 | 06:55 AM
Hello,
Did you let it dry out and check the footwell area and fuse box area in the lower foot wells. Possible that water got past the cowl tray or from a bad window repair.
Old Jun 4, 2020 | 12:10 PM
Hawaiidabest
Hello,
I looked and it seems dry and it has rained since and I have not seen any water. What can I look for if the cowl tray was bad?
Old Jun 4, 2020 | 01:03 PM
Ok,
Make sure that the rubber against the window which is part of these trays is ok and not damaged and dry roited/ cracked. Also the tray itself is not damaged and the snap in covers are on. They fade and crack.
R60 MINI Countryman R61 MINI paceman Cowl Kit
https://www.ecstuning.com/b-genuine-...51719808095kt/
Old Jun 4, 2020 | 05:54 PM
Hawaiidabest
Ok,
Hello!
I just checked and the snap on the battery cover was broken. Can this small thing really lead to a leak? I’ve attached photos for you to check out the seal and the snap. Should I still use a automatic car wash?
Snap is broke
Old Jun 5, 2020 | 10:39 AM
Looks like its sealed down and the cover should be fine and seal down. You might have a bad front window repair or maybe a door seal or someone cracked the side window down?
Check those out and till you find it i would hand wash it.
Old Jun 5, 2020 | 01:50 PM
Hawaiidabest
The windshield has a mini badge so I guess it is the original. I’ve check the door seals but could not find anything. The car is 8 years old but I don’t know when seals might go bad. Should I bring it into the shop? Or should I wait until it happens again and then go in. I also have roof racks I’m not sure if water could get into them.
Old Jun 5, 2020 | 01:58 PM
I would hand wash and take the panel out and see where the water is coming from, the only other place is the sunroof drain tubes.
https://www.realoem.com/bmw/enUS/sho...diagId=54_0440
see # 2 under the sunroof, they can come off or pop off.
https://minicooperforums.com/forum/g...of-drain-8955/
Old Jun 5, 2020 | 04:00 PM
Hawaiidabest
Hi!
Unfortunately I do not have a sunroof :/
LiftedR60
R60/R61 Stock Problems/Issues
Mar 10, 2020 06:00 AM
mountaineer2014
Feb 12, 2019 06:25 AM
Jaschen0103
Dec 5, 2016 09:12 PM
hollylemaster
Jul 4, 2009 10:20 AM
