2nd Gen Countryman (F60) Talk (2016-2024) Second Generation Countryman discussion. F60
F60 Manual Transmission Oil Change
Old May 25, 2020 | 04:29 PM
4470philip's Avatar
4470philip
I have a 2017 Mini Cooper S Countryman all4 (F60) with the 6-speed manual transmission. My research tells me that the tranny is an Aisin-sourced product, NOT the typical Getrag 6-speed manual found in most Gen 3 Minis. I need to change the tranny fluid. I know the correct new fluid to use. I can see the drain plug on the lowest part of the housing.
BUT, WHERE IN THE FILL LOCATION???
There are no other usual threaded fill plugs to be seen in the customary sides of the transmission case, like in the Getrag version.
So, how do you re-fill the tranny once you drain the fluid??
Thank you.
Old May 25, 2020 | 05:29 PM
creep's Avatar
creep
not sure if this helps, but here's what I found on TIS:
https://www.newtis.info/tisv2/a/en/f...box/1VnZ9samtA
Old May 25, 2020 | 06:05 PM
4470philip's Avatar
4470philip
Thank you.
At least, I know that it can actually be done. Now, I've just got to spend time looking for that fill plug location.
Thanks, again.
XsV
24
Sep 30, 2015 03:17 PM
Dwight Walhood
Dec 8, 2010 11:29 PM
Squadron
Mar 25, 2008 07:19 AM
hemiheaded18
May 23, 2007 04:16 PM
topher evans
Dec 16, 2004 07:24 AM
