2nd Gen Countryman (F60) Talk (2016-2024) Second Generation Countryman discussion. F60
F60 Codes....
Old May 25, 2020 | 08:10 PM
ajolly's Avatar
ajolly
Codes....
Hey all,
Can someone please help me out with the following codes:
03178A
8053A5
Anyone ran into these or have a decoder to work out what to do?
AJ
Old May 29, 2020 | 03:05 PM
beken's Avatar
beken
I just took a quick look at one of the BMW forums. 8053A5 has to do with the ASD (Active Sound) That is the exhaust sound that is piped into your cabin so you think you hear wonderful motor noises when you are driving.
It seems you can reset that in with Bimmercode.
I am not sure about a Countryman (I have one) but if you have an OBD2 scanner, try resetting the code and see if it comes back. The codes could be intermittent issues.
After programming with ISTA/P V3.56.1
 Active Sound Design (ASD) no longer provides simulated engine sounds
 A fault is stored in the ASD module.
Fault Code 8053A5 "ASD; invalid coding data for equalizing" CAUSE Invalid ASD coding data
Good luck.
ZRXChris
R55 :: Clubman Talk (2008+)
Nov 14, 2019 04:51 PM
Pitbullsmb
Oct 23, 2019 03:28 AM
igor2009
Off-Topic :: Autos
Jan 28, 2017 01:17 PM
NashvilleMiniStan
Mar 14, 2010 07:47 PM
Ex-Pat Brit
Dec 26, 2007 06:51 PM
