09 base model speedometer and tachometer
Old May 17, 2020 | 06:01 PM
ohyeahhhhhh's Avatar
ohyeahhhhhh
Hey all, first post here! I just installed the radio + speedo unit (with a new mainboard), and the radio came back alive! However, the display under the tachometer is now dimmed and I lost the speedometer and the fuel indicator. Oh, and the blinker sound is gone too. Does anyone have similar problems before? Any recommendations are appreciated!
only radio works
engine is on, tachometer works (showing RPMs), but the display is dimmed and grayish
Old May 18, 2020 | 07:44 AM
MiniToBe's Avatar
MiniToBe
you must've forgotten to plug the speedometer. double check your connection.
Old May 18, 2020 | 10:08 AM
ohyeahhhhhh
Thanks! Let me take the radio out again and check.
Old May 18, 2020 | 05:02 PM
ohyeahhhhhh
It indeed is a cable to the speedometer that I forgot to connect. It took me an hour to get the radio out, plug it, and then install everything again. Thanks for your help!
Old Jun 15, 2020 | 06:33 AM
Lex2008's Avatar
Lex2008
After I swapped in the replacement low tone horn and the new windshield washer pump, the central instrument cluster came back to life. Explain that to me...and the click-click-click of the turn signals is also working now.
I did try and get error codes from the cluster using AutoEnginuity with BMW module but I could get no access when the cluster was dead (makes sense). Im gonna try it tonight now that the cluster is working.
Old Mar 10, 2022 | 02:23 PM
Lex2008's Avatar
Lex2008
I ordered a used speedo and installed it. Its worked fine ever since. It turned off once for a brief bit then came back on.
Used was cheap. Dont bother with remanufactured/repaired.
Old Mar 12, 2022 | 11:18 AM
Coopfly1's Avatar
Coopfly1
Similar issue, no lights in tach
I have a similar issue. None of the lights in the tach work. All of the lights in the speedometer work. The needle in the tach works. ??? I'm guessing maybe something in the speedometer that sends the tach info???
Old Mar 12, 2022 | 11:26 AM
Lex2008's Avatar
Lex2008
Dont know but that one is easy to change. Check fuses, check connection to the unit and then if all looks good just buy a used one.
Old Mar 13, 2022 | 02:14 PM
Coopfly1's Avatar
Coopfly1
Thank you. I checked all fuses. I just ordered a used one on eBay. Hopefully that will work.
Old Mar 14, 2022 | 07:28 AM
Lex2008's Avatar
Lex2008
Awesome. Keep us posted.
Old Mar 19, 2022 | 07:30 AM
Coopfly1's Avatar
Coopfly1
Swap didn't solve the problem 😭😭😭 Would have been so easy. Anyone have a pinout for the wires to the tach?
Old Mar 19, 2022 | 09:34 AM
Lex2008's Avatar
Lex2008
​​​​​​I do. What's the VIN? I'll check All data.
Old Mar 19, 2022 | 12:06 PM
Coopfly1's Avatar
Coopfly1
WMWMF735X9TT99587
Thank you!
Old Mar 20, 2022 | 07:32 AM
Lex2008's Avatar
Lex2008
AllData is making finding this connector a nightmare...I cant find it.
I just read your first post. I may have changed this same system when my speedo/gas gauge failed. I bought a used unit. Maybe yours was faulty or their is a bad connection? I remember it was a delicate procedure.
Old Mar 20, 2022 | 07:42 AM
Coopfly1's Avatar
Coopfly1
Again, thank you your help! Is that the connector for the tach? From what I've read, it seams like the tach data comes through the speedo. Are you saying that maybe I have either a bad connection from the speedo or a fault from the speedo? I haven't pulled that out yet, as it is not as easy as the tach.
Old Mar 20, 2022 | 07:54 AM
Lex2008's Avatar
Lex2008
yes for the tach. Alldata says "The engine speed for the speed counter is made available via the K-CAN."......the digital speed/MPH.
When I changed my large SPEEDO unit with a used unit I also changed the radio LED using this video. Could you have a bad connection?
Old Mar 20, 2022 | 08:04 AM
Lex2008's Avatar
Lex2008
Alldata says:
Instrument dials
The instrument cluster consists of two components. The actual instrument panel is in the centre of the dashboard.
The auxiliary instrument is on the steering column.
NOTICE: Auxiliary instrument connected to the K-CAN
The auxiliary instrument (KOMBI2) is connected to the K-CAN. The instrument cluster (KOMBI) is connected to the auxiliary instrument via the body bus.
Instrument Cluster System Test
System test
The system test permits simple, visual assessment of the functions in the instrument cluster:
- Pointer instruments
- Displays
- Backlighting of all displays
- Warning and indicator lamps
Selecting system test function:
The system test can be started at terminal R (radio position), terminal 15 "ON" (ignition "ON"),vehicle and engine stopped. The system test can be started in different ways:
- by means of "Component activation" with a diagnosis telegram
- by calling up the test function 02 (system test).
The system test is started via the test function 02. This test function is not locked. The test functions are started by pressing the trip recorder reset button in the instrument cluster. Keep the button pressed for longer than 15 seconds.
The display now contains: 01._ _
Briefly pressing the button switches to the system test.
The display now contains: 02._ _
Briefly pressing again starts the system test.
The elements activated are:
- All pointer instruments
- All LC displays with a segment test and their background lighting
- All indicator and warning lamps
- Variable indicator lamp (check control symbols)
- Gearbox program / gear display
- Turn signal indicators
Oh ...I may have found it:
Old Mar 20, 2022 | 08:09 AM
Lex2008's Avatar
Lex2008
See if your connector in the steering column is 18 pin...if so this may be the correct connector.
Old Mar 20, 2022 | 09:24 AM
Coopfly1's Avatar
Coopfly1
I have to leave town so no more diagnosing until Wednesday. I will check all that out. Thank you so much again for the info! I believe it is an 18 pin. Here is a picture of the tach connection.
Old Mar 20, 2022 | 09:50 AM
Lex2008's Avatar
Lex2008
Ya that's her. Obviously #1 Make sure you're getting 12 volts.
I wish I could find the voltages for the pins for you my friend. All data is so circuitous and i don't have enough experience working on electrical and using all data for that.
Maybe the Bentley manual would be easier to search directly. Do you have access to one?
Old Mar 20, 2022 | 09:52 AM
Lex2008's Avatar
Lex2008
What the hell...i uploaded pics of the pins... Where the heck do it go? I'll upload later.
Old Mar 20, 2022 | 12:17 PM
Coopfly1's Avatar
Coopfly1
No worries. Thanks. I don’t have access to any manuals. I checked voltages on pins a while ago. I know I had 12v on at least one. Some had none and some had either 3 or 4 volts. I think I’ll eventually pull the speedo and try to trace it from there.
Old Mar 21, 2022 | 06:34 AM
Lex2008's Avatar
Lex2008
I think that because I copied and pasted the image rather than uploading it, it didn't work the first time. Also, I looked through my Bentley manual and couldn't find anything of value.
Connector: X9002
Old Mar 21, 2022 | 04:37 PM
Coopfly1's Avatar
Coopfly1
That's excellent! Thank you. I'll check it when I get back in town. I imagine there may be a bad connection in the can bus or somehow not getting all info from can bus.
Old Mar 21, 2022 | 04:53 PM
Lex2008's Avatar
Lex2008
yes they did mention a failed controller as possible cause in ALLDATA. This is coincident with your doing some work on the speedo so...maybe you fried the control unit?
