R52 driver's window won't drop when opening the door
Old May 16, 2020 | 10:05 AM
doxbike's Avatar
doxbike
So, replaced the driver's side quarter window regulator due to a broken cable and all works well, except now the driver's window does not drop when opening the door. so I have to push in on the top of the window when closing the door so it will seal. The passenger's side drops fine. Something I did when installing the regulator or something else I need to check? BTW, the top is working again. The damn thing is so intermittent that I can't find the problem. Might work 15 times, then quit working after once or may stop working 1/2 way up or down.
FWIW, the car is sitting sideways on my sloped driveway in front of my garage with the driver's side on the uphill (15-20° pitch) if that could make a difference on the window not dropping.
Old May 16, 2020 | 10:24 AM
Oldboy Speedwell's Avatar
Oldboy Speedwell
Did you reinitialize the reference point?
Hold the switch up with door closed for at least 5 seconds.
Old May 16, 2020 | 10:34 AM
MVPeters's Avatar
MVPeters
Hold the switch up with the door closed for at least 5 seconds.
I think 10 seconds works better & then hold it down for 10.
Old May 16, 2020 | 10:50 AM
doxbike's Avatar
doxbike
Thanks to both, I did not, will do so.
Old May 16, 2020 | 11:01 AM
doxbike's Avatar
doxbike
Thanks, guys, fixed!
alconk
Mar 2, 2020 03:41 PM
ericfreeman
Aug 18, 2017 11:03 AM
Pinball Rick
Electrical
Sep 14, 2009 04:25 AM
