P173b code w/o CEL after thermostat housing upgrade
Old May 13, 2020 | 12:28 PM
psheets's Avatar
psheets
2012 Countryman S ALL4
I replaced the thermostat housing with the new version that incorporates the coolant temperature sensor, replaced the top radiator hose with the one that deletes the stock temperature sensor, and replaced the wiring harness adaptor to connect to the new thermostat/coolant temperature sensor plugs.
I am still seeing a P173b fault code on my scanner but there is not a CEL. The engine temperature is being read accurately and seems to be normal. It does not get above 220ish while driving hard.
Any idea, where to start troubleshooting?
Old Jun 1, 2020 | 12:37 PM
MiniToBe's Avatar
MiniToBe
did you clear the code and it came back?
Old Jun 1, 2020 | 12:40 PM
psheets's Avatar
psheets
It seems this was an issue with the Torque OBD-II scanner app I was using. I downloaded a BMW/Mini specific app (BimmerLink) and was able to clear the temp sensor error and it has not returned since. I believe the original error was leftover from before I changed it and Torque would not clear it.
Old Jun 1, 2020 | 12:42 PM
MiniToBe's Avatar
MiniToBe
Excellent
Old Jun 1, 2020 | 12:55 PM
psheets's Avatar
psheets
I almost broke down and took it to the dealer. Was really at the end of my rope troubleshooting it.
psheets
May 15, 2020 06:43 AM
yyj3869
Apr 6, 2020 10:59 AM
mish
Apr 23, 2018 10:57 AM
Mindspin311
Sep 10, 2012 12:05 PM
