Vanos fault. Phasers?
Old May 9, 2020 | 11:13 AM
Gerard778's Avatar
Gerard778
Hi folks.
I've got a 2007 Mini Cooper (non-turbo) which has had an infuriating vanos fault for months now.
I keep getting codes 283D, 287D and 2845 and the idle is rough and fluctuating.
I have replaced the following, to no avail:
Timing chain, guides and crankshaft sprocket (Febi Bilstein), including new stretch bolts on crank and phasers.
(Crank bolt torqued to 50Nm then 180 deg. Phaser bolts torqued to 20Nm then 180deg)
Both vanos solenoids.
Both camshaft position sensors.
O rings on the exhaust camshaft.
The timing is absolutely spot on using a Laser tool.
Oil pressure is 50psi at 3000rpm at the pressure sensor.
When I reset the vanos adaptations, the exhaust value is 60, when it should be between 40 and 60, and that's the crux of the problem. The inlet value is bang in the middle.
There is no visible scoring on the exhaust cam journal, closest to the phaser. The metal O rings looked fine but I replaced them with the new rubbery ones anyway.
Basically, the only thing left to replace is the exhaust vanos phaser but I'm loathed to do so
a) because they're expensive
b) I'd rather know that it was actually knackered before replacing it
My question is: What can go wrong with these things?
I bought a cheap used one and took it apart. There doesn't appear to be anything inside that can break. I did see a spring loaded locking pin, which I assume locks the phaser at the rest position when there's no oil pressure, but I think that's unlikely to break.
Please help as this is slowly driving me insane.
Old Jul 5, 2020 | 06:15 AM
luis89lxi's Avatar
luis89lxi
Did you find a solution for your car ? I have a similar issue, timing is ok, cam pressure rings ok, solenoids, and still have the VANOS and cam sensors code for both banks.
Luis
Old Jul 5, 2020 | 07:53 AM
Gerard778's Avatar
Gerard778
Luis
Yes, I did find the issue. Although I had replaced both vanos solenoids, I used aftermarket items, not BMW Mini parts. Once I'd ruled out every other component, I decided to replace both vanos solenoids with genuine Bmw Mini items. This instantly fixed my problem. Lesson learned. Remember to reset the adaptations if you replace these solenoids. Good luck. Let me know how you get on.
Cereall
Jan 31, 2018 07:44 AM
geofox784
Jun 14, 2017 11:31 AM
ladzio
Apr 16, 2015 05:33 PM
brsmini
Aug 10, 2008 03:50 PM
koenner1
Jun 28, 2005 01:47 AM
