Suspension 'Loading' the suspension?
Old Apr 16, 2020 | 07:47 AM
JAB 67's Avatar
JAB 67
I just placed Powerflex inserts in my rear trailing arms. The instructions urge me not to fully tighten and torque the bolt until the suspension has been 'loaded.' What exactly does that mean? I assume what they want me to do is put the wheels on, take the car off the blocks, and at a minimum bounce the rear to give the inserts the opportunity to fully settle in, then torque. Correct?
Old Apr 16, 2020 | 08:33 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Community Influencer
Disconnect the sway bar link, then place your jack under the hub and lift until that corner of the car lifts slightly off the jack stand. At that point, the suspension on that corner will be loaded and you can torque the bolt.
Old Apr 16, 2020 | 09:28 AM
JAB 67's Avatar
JAB 67
Old Apr 16, 2020 | 04:22 PM
OCR's Avatar
OCR
"Loaded..." means just that, the suspension at full car weight.
And if you are over about 150 or so pounds in weight, I'd add that also.
Put the car on four jack stands, bricks, whatever you may have so that you can safely crawl under it, with the car level. Then...tighten to the given torque spec.
Pretty silly to put the chassis "into a corner" mode. Think about this for just a second... Just what is the percentage of time that you spend "in a corner" vs, driving on flat ground..!
Sorry, but the answer to put the chassis at an angle (post 2) makes zero sense.
Mike
Old Apr 16, 2020 | 05:18 PM
cmt52663's Avatar
cmt52663
I respectfully suggest that you may be mistaken? ;-)
njaremka suggests a more convenient way to achieve compression of one corner, by simply picking up the weight that WAS on that jack-stand using a jack at the hub. That leaves the car level (if done as suggested) and will put the suspension at the appropriate level for torquing.
I kinda thought it ingenious myself...
Cheers,
Charlie
ojamir
GP Talk
Oct 28, 2017 06:22 PM
jd_martin
Suspension
Dec 22, 2009 07:51 AM
SparklingMini
Jul 4, 2008 12:37 PM
