FS:: 2008 Cooper S - Slick Top, Manual Trans!
Year: 2008
Price: $4200
Mileage: 96000
Color: Red/ white
Location (Region): Midwestern
VIN: WMWMF73588TT93799
6-speed manual transmission
slick top (sunroof delete)
Clean Title
AUTOCROSS SPECIAL!!
Newer tires - maybe 3k on them
Newer brakes front and rear - 5k miles on them, maybe?
New valve cover assembly - aftermarket, works exactly the same , yet 1/2 price.
Newer battery 2019
Clutch replaced at 88K
New oil filter housing gaskets, including cooler gaskets
New turbo feed line and oil drain line
BRAND NEW high pressure fuel pump -- paid for, not from extended coverage..
New vacuum pump.
Installed cold weather intake manifold ( I'm in Chicago)
Replaced 3 piece intake piping with new single piece boost tube (from map sensor to intake manifold)
Bought the car because I needed a Daily Driver, my SRT4 only gets 11mpgs..
Bought the MINI with a failed timing chain assembly, pistons hit valves.
Cylinder head was sent to machine shop, decked, cleaned, all 16 valves replaced, all valve stem seals replaced. 8 lifters (exhaust) replaced.
Timing chain assembly replaced (OEM)
Head gasket, head bolts (stretch bolts) replaced (OEM)
Water pump, Thermostat, and connecting tube under intake replaced (OEM)
Turbo feed line, return line and attaching hardware all replaced (OEM)
Exhaust camshaft replaced per machine shop recommendation (vacuum pump failed)
Replaced vacuum pump assembly - original reason timing chain failed
Oil pan removed, cleaned and re-installed with new sealant for gasket
Exterior:
Replaced front fog light housings - had corrosion so bad they barely emitted light
Replaced missing chrome trim on bumper and hood.
I've been driving this for awhile now, but it seems i still perfer the 11mpg SRT4.
I have reciepts for all the parts, and 2/3 of them have a 2year wty, (maybe 13 months left?) as they were purchased at the MINI Dealer.
I only have the One key fob for the car, but if interested, can get a second key for a serious buyer
We have emission testing here, and the MINI does pass the test.
I personally built this MINI,minus the machining of the cylinder head. I've worked for MINI for several years
This was meant to replace my R53 that I sold because the roll cage didn't allow a car seat in the back.
Shockingly, the R56 doesn't seem to fit a car seat as well as I was assuming.
Has factory rubber floor mats, they seem to fit the best.
Front plate bracket is included, I perfer the no front plate look!
Willing to help with shipping or delivery if required, for a serious buyer
Rich 630-six75 - 86four6 call or text.
secondhandr55
R55 :: Clubman Talk (2008+)
Mar 9, 2019 06:29 AM
GsxR1000
Dec 8, 2018 06:34 PM
