Airbag light on after wet interior
Old Apr 7, 2020 | 02:30 PM
Grusvag's Avatar
Grusvag
Left our sunroof open while we got some rain and now the airbag light is on on the instrument panel. We've tried drying the interior out but am wondering
a. Are there connectors under the seats that we should check? See if we can dry them out, put some grease in there and reconnect? I've read that there were connector issues here in the 1st gen cars.
b. Will we have to take the car to a dealer to have the light turned off?
TIA.
Old Apr 8, 2020 | 09:21 AM
Footwell module got wet. You need to dry that unit out and check the connections. Also the fuses. https://www.northamericanmotoring.co...solutions.html
https://www.newtis.info/tisv2/a/en/r...odules/IRPCRZe
Old Apr 8, 2020 | 05:22 PM
Grusvag's Avatar
Grusvag
Thank you! Will check it out and report back.
Old Apr 8, 2020 | 05:23 PM
Welcome.
Old Apr 8, 2020 | 11:53 PM
club_c's Avatar
club_c
Do not unplug the harness under the seats to service! Even if you unplug and replug, it knows! That will throw the airbag error and you’ll need the code cleared by a shop (don’t ask me how I know...)
Old Apr 10, 2020 | 11:40 PM
allenm324's Avatar
allenm324
Just disconnect the negative battery terminal before you unplug the harness and don't reconnect it with it unplugged; it does know. Also, you can buy one of these MyCarly adapters to clear the code and most any code. It does quite a few other things too.
jma
F54 :: Clubman Talk (2015+)
Jun 16, 2019 01:09 PM
Hazzard01
May 1, 2014 02:40 PM
chrisneal
Mar 25, 2006 08:57 PM
