Oil Leak Cause?
Oil Leak Cause?
My 2011 JCW is leaking oil from under the front passenger side. Pretty much right under the dipstick (maybe a little behind it). Oil level doesn't seem to be dropping at all, and it's not a huge leak (couple of drops per night). Any ideas on the source?
If you have the time, tools, and patience, pull the wheel and fender liner off to check the engine front end. Lotsa seals and hardware to leak from located there. Otherwise take it to a Mini indi shop with a lift. Maybe they can find it for you.
Prime offenders on that end that I know of: crank seal, oil pan, tensioner, valve cover. I agree with oldbrokenwind....inspect. I'd start at the top with the tensioner and valve cover because they can leak and it can look like the crank seal and/or oil pan if you look at it from the bottom. It's probably not the valve cover....the tensioner is more common and not too hard to check.
+1 Oil pan, crank seal on the passenger side. Bugeye hit all the ones i would check.
Mine turned out to be the oil filter mount and gasket. Got that fixed and the leak is gone. It's tricky to get to, but you might want to check that out.
Sleepie
R60/R61 Stock Problems/Issues
Nov 26, 2014 08:19 PM
