R50/53 No Power assisted clutch?
Old Mar 19, 2020 | 10:37 AM
imaslowdriver's Avatar
imaslowdriver
I've noticed the clutch in my r53 is heavier and has better feel than other cars I've driven, is there no hydraulic power assist like modern clutches? I'm happy with how it feels, actually, I was just curious because I thought power assisted clutches were common after the early 2000s. I turned the engine off and pumped the clutch several times to see if it would get any heavier, and it didn't, so I'm assuming there's no assist at all?
Old Mar 19, 2020 | 10:46 AM
MrBlah's Avatar
MrBlah
6th Gear - AX Champion
it's a hydraulic clutch like all modern cars, uses the same brake fluid as your brakes
Old Mar 19, 2020 | 12:20 PM
imaslowdriver
But then why doesn't it get heavier like my brakes if I pump it when the engine is turned off?
Old Mar 19, 2020 | 12:42 PM
gumbedamit's Avatar
gumbedamit
That's because, when you pump the brakes, the calipers fill with fluid which can't be compressed. When you pump the clutch, it pushes a piston in the slave cylinder, then releases from the spring loaded clutch.
Leminamcnair
Jul 3, 2018 06:08 PM
whippa
Mar 1, 2017 09:28 AM
diablotoona
Mar 24, 2011 03:39 PM
Stanislaus
Jun 23, 2009 12:28 AM
meb
Apr 4, 2008 11:24 AM
