R58 backup (reverse light) not working on 2012 R58 JCW
Old Mar 15, 2020 | 05:33 PM
mtbdavid2's Avatar
mtbdavid2
Hi,
The backup (reverse light) is not working on my 2012 R58 JCW 6 spd. manual transmission. I just purchased the car and realized today the backup single light is not working. The bulb is fine. There is no power going to the socket when in reverse. Is there a fuse for this bulb and if so, what fuse number on the passenger side fuse box? Is there only a backup light switch on the 6 speed manual transmission? Apparently there are rear fog lights but I don't think I have the switch for it. There is only one switch for the front fog lights. Any help would be greatly appreciated.
Old Mar 18, 2020 | 12:21 PM
minidd99's Avatar
minidd99
There is no switch for the reverse light. When you put the shifter into reverse it should engage a switch to turn on the light. Your owners manual should be able to tell you which fuse to check.
Old Mar 19, 2020 | 05:56 AM
I dont have my r58 JCW right beside me but check all the fuses. https://www.newtis.info/tisv2/a/en/r...nctional-info/
This has some technical diagrams if its not the fuse. Make sure the socket is ok ( pins like to move) and the wire going to it near the back.
STLMINI
Dec 14, 2015 07:52 AM
RideHard
Jan 9, 2010 04:53 PM
scottab36
Electrical
Dec 2, 2008 04:47 PM
burley
Sep 5, 2007 12:29 PM
Xman
Dec 18, 2004 02:20 AM
