R52 2006 Top Dash Pad Removal
Old Feb 25, 2020 | 05:46 PM
A383Wing's Avatar
A383Wing
Does anyone have a link or detailed instructions on how to remove the upper dash pad from a R52?
The service manual is useless, I have searched the Web and in here...nothing really helped there either....
I need to remove the top of my dash...mainly just the top pad....any help appreciated....
Bryan
Old Feb 25, 2020 | 06:42 PM
shrevemini's Avatar
shrevemini
Top Answer: 1
Bryan
Real easy. Pop out the panels on both sides of the dash You will need to pull the door seals loose to reinstall panels. Remove 2 t25 torx screws either side.
Then remove the conmvers on the hazard an dimmer. Just pull. The pull off. Then above the covers you removed you will see 2 screws. Once you remove these screws. The cover will lift up an your all set.
Old Feb 25, 2020 | 08:14 PM
A383Wing's Avatar
A383Wing
That works for my '04 R53, but I think there's a lot more to this on my '06 R52.
I pulled the screws you said above, plus the 5-6 at the top defrost openings, the 4 behind the passenger side trim cover, I still can't get this pad to move....
There's got to be some that I'm missing... but I can't find anything....
Appreciate your help, but I'm thinking that the R52 isn't the same as the others
Bryan
Old Mar 5, 2020 | 12:29 PM
Here is the 2005+ removal, did you look here? https://www.northamericanmotoring.co...p-removal.html
Performance Angst
Jan 26, 2019 12:00 PM
pichufo
May 19, 2008 12:36 PM
ZJedi945
Mar 27, 2008 03:45 PM
danbanger
Sep 13, 2007 03:25 PM
COOPED UP
Oct 28, 2006 05:10 PM
