Interior/Exterior Removing Top dash vent
Old Jul 10, 2007 | 01:32 PM
danbanger's Avatar
danbanger
Hello I am not looking to remove my dash, but the vent that is sorta above the speedo. Can I just pop it off?
BTW my car is a 2005 MC.
Old Jul 10, 2007 | 02:56 PM
CooperGear's Avatar
CooperGear
From: Greater Chicagoland. Ich Bin Ein Midwesterner!!!
Nope.
You can not remove this vent. It is part of a larger part under the dash pad.
Why remove it?
Blake
Old Jul 10, 2007 | 04:04 PM
03Indigo's Avatar
03Indigo
User Title's are Silly
you can remove it, it requires removal of the dash top part, then you grind down the plastic welds that hold it inplace. You can use an epoxy to re-attach it. I did it when I re-covered my dash.
Old Jul 10, 2007 | 05:20 PM
CooperGear's Avatar
CooperGear
True, but keep in mind. The '05 car has a different airbag setup and that is a whole different can of worms than your car.
Old Jul 10, 2007 | 08:30 PM
03Indigo's Avatar
03Indigo
not totally, just a different molding of the dash, with break away points, it still mounts/bolts in pretty much the same way, from the sides...and the center vent is still mounted in the same fashion.
Old Jul 10, 2007 | 08:42 PM
ohs68's Avatar
ohs68
You know, this is a timely question. A buddy of mine is trying to install a Kuda brand GPS mount on the dash of his 2005 Mini. The mount he was sent is different from the photos of an R53 mount I've seen in NAM threads in that the metal piece that fits under the dash vent has a step in it. Thus, there's no way he can just slip it under the vent as would seem to be the case with the earlier model. I'm waiting for a resolution of this problem before ordering a Kuda mount for my '05 Mini. Any thoughts on this issue would be appreciated!
Alan
Old Sep 13, 2007 | 03:25 PM
Speedee's Avatar
Speedee
Just completed the Kuda Mount in my '06 MCSa... Yep, the front flange on the Kuda had a "step", I didn't see how it would fit, so I was going to remove the dash cover to facilitate installation... Then realized that the newer (05-06) passenger airbag deploys UP through the dash cover... That nixed removing the dash cover. SO... With a little prying, the center vent will open enough to insert the "step" tab, and sure enough, it snaps down into place, making a real snug fit... Just be sure you attach the mounting stem first, because once installed, these mounts are a bear to remove!
Overpolished
Detailing 101
15
Aug 21, 2015 07:19 PM
Shane Wendel
Aug 21, 2015 01:04 PM
Aug 19, 2015 12:51 PM
AZN Optics
Aug 16, 2015 11:52 PM
