Suspension Skqueak in front end after H-Sport spring installation
Old Dec 16, 2004 | 07:03 AM
FATBOY59's Avatar
FATBOY59
Squeak in front end after H-Sport spring installation
I installed H-Sport springs in my MCS and now a loud squeak has developed coming from my right front strut area. It squeaks when making tight turns at low speed (<5 MPH) .It is very difficult to pin point the source. Anyone else have this? I removed the strut assembly to make and verified that the bearing on top was not binding.
Any help would be appreciated.
PS. I am running 215-40-17 on S-lite wheels, H-sport springs with no rubbing issues at all.
Old Dec 16, 2004 | 10:00 AM
JCampos's Avatar
JCampos
I have the same but for the left side. Cant tell if tis coming from the front or the back and since I did my springs/rear swaybar at the same time I cant tell which it is.
Old Dec 18, 2004 | 03:41 PM
Nitro22's Avatar
Nitro22
I would double check all nuts and bolts. Visually check all components and make sure they are in the correct position/alignment.
If you cannot find anything wrong then it might be necessary to uninstall the springs and re-install them from scratch.
From my experience, most noises come from installation mishaps.
Good Luck!
Old Dec 19, 2004 | 09:39 AM
JCampos's Avatar
JCampos
Done all that already, I think I just need some more LUBE
Old Dec 19, 2004 | 10:11 AM
early_apex
Probably. Make sure the springs are seated properly as well.
Old Dec 19, 2004 | 10:16 AM
JCampos's Avatar
JCampos
They are.
Ryephile
Suspension
113
Feb 9, 2020 03:43 PM
silence2-38554
Nov 12, 2015 09:39 AM
squawSkiBum
Oct 2, 2015 09:21 AM
FatherG
11
Aug 7, 2015 07:49 PM
