R56 Rear hatch unlocks by itself!
Old Feb 23, 2020 | 10:59 AM
Grusvag's Avatar
Grusvag
Every once and a while the rear hatch unlocks itself while driving the car. Any thoughts as to why this might be happening?
Old Feb 23, 2020 | 11:27 AM
msbragg's Avatar
msbragg
I carry my key fob in my pocket and sometimes my wallet or something else in my pocket will press the button and unlock the hatch. Maybe that’s what’s happening to you.
Old Feb 23, 2020 | 12:05 PM
Grusvag's Avatar
Grusvag
Nope. This is while the engine is running and the fob is in the ignition slot.
Old Feb 23, 2020 | 12:54 PM
KeyPlayaJim's Avatar
KeyPlayaJim
Every once and a while the rear hatch unlocks itself while driving the car...
My 2013 R56S has been doing the same thing occasionally for a few years. It usually happens when the engine is running, but not necessarily, and always with the key fob in the slot.
The dealership's service manager has no idea what is causing it. He wanted to keep the car for a couple days so a mechanic could drive it around in the hope of catching it in the act, but I didn't like the idea in general, plus it's so random that I didn't think they were likely to catch it.
I'm wondering if something is coming into contact with the hatch unlock button (edit: on the fob) when the fob is inside the slot, but I can't see anything that might do that.
It's a bit frustrating. I always try to remember to check the hatch when I leave the car.
Old Feb 23, 2020 | 02:17 PM
Capt_bj's Avatar
Capt_bj
I'd open up the rear switch/tag light and see if there's any water intrusion ..... it comes off with just a couple of torx screws (4 I think) . . .
#6 holds the micro-switch for the release . . .
could be water or even just a loose connection ... unplug it and use a lil contact cleaner and re-seat ....
Old Feb 23, 2020 | 02:50 PM
Grusvag's Avatar
Grusvag
Thanks - will try that and let you know!
Old Feb 25, 2020 | 07:42 AM
yep, bet the water got in there or that micro-switch is on the fritz https://www.northamericanmotoring.co...ing-diy-2.html
Old Feb 25, 2020 | 08:45 AM
KeyPlayaJim
Does this require removing the inner panel from the hatch, or is it all done from the outside?
Old Feb 25, 2020 | 08:58 AM
Katgirl's Avatar
Katgirl
Good thinking, Capt. B.J. 👍
MrFunk
Feb 21, 2018 02:49 PM
joey1320
Mar 26, 2012 07:25 PM
boxerboy43
Oct 28, 2006 04:39 PM
PiercedMini
Oct 2, 2006 09:36 PM
Arty13
20
May 4, 2006 06:44 AM
