Boost pressure issue.
Old Feb 23, 2020 | 10:55 AM
marquez ceballos's Avatar
marquez ceballos
So I'm looking for any help I can possibly get here I can't seem to find the issue.
I recently replaced the thermostat housing and water pipe that runs behind the block because the car was leaking coolant. After we finally got all the coolant leaks fixed and go to test drive the car. The car is idling normally started after a week with ease and has normal vacuum numbers. However the car will not build boost and entered limp mode. Throwing a check engine light for a downstream throttle air leak. I have pulled the diverter valve out and looked at it. The diaphragm seems to be fine and still in one piece.
At this point I am thinking maybe a waste gate vaccum line leak. However I couldn't seem to find where the vaccum line runs to. Any diagrams or other ideas would be much appreciated thank you so much to anyone that has an idea of how to fix this.
Old Feb 23, 2020 | 02:34 PM
oldbrokenwind's Avatar
oldbrokenwind
Time for you to learn about the illustrated parts list most of us use --- https://www.realoem.com/bmw/enUS/select There's a diagram in there you should be able to figure out.
Also, as a "newbie" to the forum, you might someday want to use the repair procedures Mini techs use --- https://www.newtis.info/tisv2/a/en/ well illustrated and complete with torque specs.
Have fun ---
MrGrumpy
R60/R61 Stock Problems/Issues
14
Nov 15, 2024 08:15 AM
psymonp@gmail.com
Oct 31, 2016 11:52 AM
johntotah94
May 10, 2016 10:46 PM
zcast
Jan 22, 2015 02:50 PM
SooperCuperErik
Dec 16, 2011 11:58 AM
