R50/53 Bargain $500 Mini- Initial Start Up Question
Old Feb 23, 2020 | 10:42 AM
robj's Avatar
robj
So in the course of fixing everything I could think of, I've disturbed quite a few systems and the potential for leaks or other issues is always present.
But the exhaust is on and the only thing left to do before noise and smoke is adding coolant.
As the bumper cover isn't on for real yet and the taillights are out I'll have bulb codes [warnings?] out the wazoo.
Will having all this lighting stuff unhooked affect anything else?
And, when all the lighting is hooked up will the bulb warnings/codes just go away? I really would like to start the engine to make sure everything is good just in case I need to fiddle with engine parts before putting the bumper cover etc... on for real.
One other question, does the key fob charge anytime the engine is running or do you have to be driving?
Any advise is welcome,
robj
Old Feb 23, 2020 | 04:35 PM
mildensteve's Avatar
mildensteve
You should invest in a Mini code reader/reset-er. You WILL need it. If not immediately, immediately after. I assume you will start it on the jack stands to look for leaks. Make sure you bleed the coolant using the bleed valve. Don't forget power steering fluid and to bleed it too. Turn the headlights to off not Auto. Your ambient temp sensor still hooked up? If not you will get codes for that also.
I am sure you thought of all that already.
Oh this is exciting!
Old Feb 23, 2020 | 04:36 PM
mildensteve
And expect to need to change out the key FOB batteries. It is not too hard and cheap insurance.
Old Feb 23, 2020 | 06:41 PM
robj's Avatar
robj
Steve,
I moved this back to the build thread. Hope you don't mind.
rob
Old Feb 23, 2020 | 06:48 PM
mildensteve
LOL not at all. Keep the story all in one place.
Old Feb 25, 2020 | 08:53 AM
gumbedamit's Avatar
gumbedamit
05/06 R53, 05-08 R52 Key Fobs are charged through the ignition
Old Feb 25, 2020 | 09:59 AM
mildensteve
And when they stop charging you either replace the battery or get a new key from Mini. I have had to change out both of my key FOB batteries for my R52. Search this forum and you will see what I mean.
clark5592
Sep 25, 2019 10:36 AM
Nikkielynn
Sep 7, 2018 05:00 PM
timcluff
Jun 2, 2017 02:27 PM
StefsCoop
Nov 2, 2016 02:31 PM
actasci
Dec 18, 2013 10:34 AM
