R50/53 intermittent crank, no start or no PS
Old Feb 22, 2020 | 09:44 PM
Ken Garchow's Avatar
Ken Garchow
my 05 MCS manual has developed an intermittent no start or no PS problem
first few times many of the dash lights would come no while driving and power steering would not be working, could pull over and turn key offf and on and car would restart with power steering and lights working as normal.
also few times when starting would just crank and not start, few cycles with the key on and off would result in it starting and working fine again
today it did the no start again and i noticed the dash lights didn't come on when the key was on, and when cranking. actually stranded me
came cack a few hours late and it cranked and started as normal
have been searching posts here for past week or so and have a few hunches as to the possible problem.
1) alternator issue not triggering the PS PUMP and causing electrical system to malfunction
2) ignition switch causing intermittent running issue
3) intermittent computer communication issue
4) replaced relay related to engine computer
have eliminated few possible issues i think: cleaned grounds, harmonic balancer slipping, battery good, no cack engine codes
wanted to see if anyone here could point me in what direction to go next
thanks!!
Old Feb 23, 2020 | 06:12 AM
jc130chief's Avatar
jc130chief
How old is your battery? Check battery install/purchase date and voltage. (KISS) Keep it simple s...
Old Feb 23, 2020 | 08:06 AM
Ken Garchow
Thanks for the reply, ill check the dates but
mini scanner showed good battery voltage
never had any battery issues, always cranks fast
Old Feb 24, 2020 | 10:33 AM
gumbedamit's Avatar
gumbedamit
Sounds like a bad battery or bad ground. When you say voltage is good, meaning the alternator is charging?
Old Feb 24, 2020 | 10:54 AM
Ken Garchow
thanks for the repy
alternator charging and battery full voltage plus always cranks well
Old Feb 24, 2020 | 11:22 AM
gumbedamit's Avatar
gumbedamit
Originally Posted by Ken Garchow
thanks for the repy
I would have the battery load tested, just because it puts out 12+ volts doesn't mean its in good shape. Alternator should be charging 14+ volts no load. If that all works out, I would look into the ground straps, make sure they are in place, not rusted and have good connections. There are 2 straps I believe, one on the front passenger side of the engine compartment , can;t recall right now where the other one is, you can search in this forum for the location of the other. Hopefully it's as simple as that.
Old Feb 24, 2020 | 07:12 PM
ssoliman's Avatar
ssoliman
+1
Intermittent electrical issue? Sounds like ground
Old Feb 24, 2020 | 08:43 PM
user 7389739's Avatar
user 7389739
+1 on taking battery in for a full test. Also, +1 on checking all major ground connections, here listed in Uncle Bentley page ECL-18 through 21. NOTE: figure 13 shows locaiton of EHPS ground X173, for power steering pump 'underneath engine compartment fuse and relay panel 3':
Bentley Mini Cooper Service Manual page ECL-18 Ground Locations
Bentley Mini Cooper Service Manual page ECL-19 Ground Locations in Engine Bay
Bentley Mini Cooper Service Manual page ECL-20, note Figure 13 shows location of power steering pump ground
Old Feb 26, 2020 | 11:01 AM
Ken Garchow
thanks everybody for such helpful information
i will address the issues brought up and reply
Old Feb 27, 2020 | 08:52 PM
Ken Garchow
problem seems to be fixed, after cleaning all grounds, load testing battery and changing relays with no improvement went ahead and changed the ignition switch. been about 4 days now of running around in the car and had no starting issues
took about 20 min to change, easy job
thanks
snowballs
Dec 23, 2019 05:41 AM
Gutling
Nov 12, 2019 08:18 AM
Mrelia
Nov 1, 2012 09:44 AM
Rogue Agent
Mar 8, 2009 07:52 PM
MyMiniME
Nov 26, 2006 04:18 PM
