What is this pipe?
Old Feb 22, 2020 | 11:05 AM
cdboss's Avatar
cdboss
What is this pipe?
This pipe sheered off when I was trying to get to my throttle body. Is it for the solenoid? Is it hard to replace? My car sounds like it has a bad vacuum leak right now.
Old Feb 22, 2020 | 11:11 AM
cdboss's Avatar
cdboss
Actually I think this is the PCV?
Old Feb 22, 2020 | 11:44 AM
cristo's Avatar
cristo
Alliance Member
Yes.
Hose from pvc in valve cover to intake manifold.
Old Feb 22, 2020 | 12:01 PM
cdboss's Avatar
cdboss
Originally Posted by cristo
Yes.
Thanks. Is this easy to replace. It's certainly cheap, but looks like it connects underneath the intake manifold?
Old Feb 22, 2020 | 01:59 PM
Jason Cornelius's Avatar
Jason Cornelius
You have to pull the intake box off and yes it’s connected to intake. I blocked mine off and car runs fine. The two plugs are cheaper than the hose, 25 bucks shipped from ECS and yes I do have an OCC on the other side.
Old Feb 22, 2020 | 02:08 PM
cdboss's Avatar
cdboss
I ordered a new one off RockAuto for $20. I was trying to replace my throttle body and just slightly moved the thing and it broke in half.
Old Feb 22, 2020 | 02:11 PM
cristo's Avatar
cristo
Alliance Member
Mine is plugged off at the valve cover
with a BSH dual boost tap and have
a BSH OCC on the other side of the
(N14) engine.
Old Feb 22, 2020 | 07:57 PM
club_c's Avatar
club_c
Reviews are mixed on blocking it off. I decided to replace it with an aftermarket one for about $35. It's relatively simple to change, the airbox and that resonator into the firewall need to be removed and you should have access...
Old Feb 22, 2020 | 08:59 PM
Jason Cornelius
over 3000 trouble free miles. I check my OCC at least once a week or fill up, bit **** but she’s my needy b.
Old Feb 24, 2020 | 12:29 PM
Here is the part and it connects near the manifold.
https://www.ecstuning.com/Search/Sit...h/11157605186/
digram https://www.realoem.com/bmw/enUS/sho...15#11157605186
Old Feb 26, 2020 | 04:20 PM
cdboss's Avatar
cdboss
I decided to go non-OEM with the PCV hose, because it was much cheaper. I got the Vaico one. However, when I put it on today, it didn't seem to bend correctly like the OEM version. I had to really force it on the connection to the intake manifold. I did hear it click, but it doesn't seem like a fully flush connection. It was quite difficult to get on. I pulled on it and it wouldn't come off. Do you think this is okay? I'm not throwing any codes anymore and everything seems fine. Idle is good and I don't hear any air leaks.
Old Feb 26, 2020 | 04:24 PM
DneprDave's Avatar
DneprDave
I blocked mine off, like Cristo did, 45,000 miles ago with no problems.
Old Feb 26, 2020 | 04:25 PM
Jason Cornelius
Originally Posted by cdboss
I decided to go non-OEM with the PCV hose, because it was much cheaper. I got the Vaico one. However, when I put it on today, it didn't seem to bend correctly like the OEM version. I had to really forced it on the connection to the intake manifold. I did hear it click, but it doesn't seem like a fully flush connection. It was quite difficult to get on. I pulled on it and it wouldn't come off. Do you think this is okay? I'm not throwing any codes anymore and everything seems fine. Idle is good and I don't hear any air leaks.
I would say you are good if cel is off. Drive her around and see.
Old Feb 26, 2020 | 04:31 PM
cdboss's Avatar
cdboss
I took it for a test drive and even did a pull. Everything is still good. I guess I'll just let it be for now. That thing was a nightmare to get on. Thanks for the reply.
Old Feb 26, 2020 | 04:35 PM
Jason Cornelius
no problem,
the nightmare for me was getting it unplugged at throttle body. The plugs I got from ECS just snapped right in and issue free still.
Old Feb 26, 2020 | 04:37 PM
cdboss's Avatar
cdboss
no problem,
the nightmare for me was getting it unplugged at intake. The plugs I got from ECS just snapped right in and issue free still.
Did you put an OCC on or just simply plug them?
Old Feb 26, 2020 | 04:44 PM
Jason Cornelius
Did you out an OCC on or just simply plug them?
OCC on the other side. I empty it once a week or every fill up, yes bit excessive but I check oil and everything else while I’m there. Makes me sleep better at night and I drive her hard.
DIY kit, brass fittings, Teflon tape on threads into OCC, stainless hose clamps all for under $50.
Old Feb 26, 2020 | 04:47 PM
club_c's Avatar
club_c
I see a few terms being thrown around a little loosely on this thread. That PCV pipe goes from the back of the valve cover to the throttlebody, not to the intake manifold. If you remove the air cleaner housing and the resonator behind it you have decent access to the connection at the throttlebody without having to remove anything else. It does take a little bit to release it at the throttlebody, but look at the connection at the valve cover to orient yourself to where the two squeeze points are on the locking collar. It's the same at both ends. I was fussing with mine for quite a while before just replacing it so got to a point where I could re and re it in about 5 minutes. I agree if the CEL is not shouting at you, you've got it figured.
Old Feb 26, 2020 | 04:49 PM
cdboss's Avatar
cdboss
I might have to do this at some point. Seems like a really straight forward install just by looking at it. Is the can annoying to get off to empty or fairly easy?
Old Feb 26, 2020 | 04:51 PM
Jason Cornelius
edited my post and thank you.
Old Feb 26, 2020 | 04:53 PM
Jason Cornelius
the one I ordered twist off, you will get the hang of it I have this all down to under 5 min job. Just make sure you empty into a container that can handle gas, NO SOLO CUP.
It’s red because it’s eating the cup
I keep in here until I have an empty qt of oil, dump it in there and take it to autozone then buy new qt of oil since I’m there.
Old Feb 26, 2020 | 04:58 PM
cdboss's Avatar
cdboss
Huh? The throttle body is on the other side of the lower manifold. I just replaced that today too, because the plate was stuck slightly open. Maybe it all connects to the throttle body somehow? Either way, thanks for the reply. I'll just have to monitor it and see, but I think it's okay. Thing was quite annoying to get on. My OEM hose was bent in a more dramatic angle to fit on easier.
Old Feb 26, 2020 | 05:09 PM
Jason Cornelius
Check your pms for vids
Old Feb 27, 2020 | 05:43 AM
Should be fine. We carry the bremmen one and it fine, you can see people post reviews on our site.
Old Feb 27, 2020 | 07:44 PM
danraabe's Avatar
danraabe
You know, i blocked off my pipe at one time and the car didnt idle well. A mechanic told me to put it back. ANd i had a catch can as well
