R56 Engine Swap N14 to N18?
Old Feb 12, 2020 | 04:32 PM
Mikey_22's Avatar
Mikey_22
New to here so don't know much but was just looking for answers on an engine Swap on my Manual 2012 R56 JCW I was wanting to know if the 2013 N18 JCW engine would be a perfect fitment in my MINI that currently has the 2012 N14 JCW engine or would there be many problems?
Manual 2012 R56 JCW Hardtop
Old Feb 12, 2020 | 08:00 PM
MWMWMWM's Avatar
MWMWMWM
Yes, too many problems. If you do a search you will fine a few who have tried and gave up. There are many variables that would require the entire wire harness to be changed out from dash to DME. It wold be cheaper and less headache to replace the car.
I researched this as well some time ago.
Old Feb 13, 2020 | 05:37 AM
MiniToBe's Avatar
MiniToBe
If you searched, you'd find my thread lol
https://www.northamericanmotoring.co...gine-swap.html
short answer is yes you can swap it and you don't need to change the entire harness from dash to DME; only few wires relocated.
Old Feb 13, 2020 | 09:01 AM
MWMWMWM's Avatar
MWMWMWM
Actually, I did see your thread when I researched the swap. Yours was still a basket case at that time. I wrote it off as a start and a give up. Your tenacity is impressive. As stated in other threads, n18s are more readily available and less expensive these days.
Old Feb 13, 2020 | 09:07 AM
MiniToBe's Avatar
MiniToBe
Lol true that...I was sucked in flipping minis I wasn't motivated to finish it...Luckily it was accomplish and now I'm doing a N12 to N18 swap
Old Feb 14, 2020 | 08:04 AM
Andernamen's Avatar
Andernamen
Do you have a thread on this swap? I have an n16 that is dead. I'd put in an n18 if it was cheaper and not toooooo difficult.
Old Feb 14, 2020 | 08:08 AM
MiniToBe's Avatar
MiniToBe
You bet https://www.northamericanmotoring.co...-with-n18.html I'm currently working few issues engine related though. It is much easier to marry the N18 ECU to the N16 CAS....in my case, I'm still using the N18 ECU/CAS/keyfob set.
Old Feb 14, 2020 | 09:39 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Community Influencer
I would sooner rebuild the JCW N14 with better components than go through the hassle of swapping an N18 into it.
Car looks great, by the way
Old Aug 12, 2020 | 06:21 PM
Corey P Whisenhunt's Avatar
Corey P Whisenhunt
what would you add
[QUOTE=njaremka;4519865]I would sooner rebuild the JCW N14 with better components than go through the hassle of swapping an N18 into it.
If you were to rebuild the 14 what would you add and change bc i think im going this route
Mikey_22
Feb 12, 2020 04:18 PM
Nabco
Apr 28, 2019 10:53 AM
clarkjk3nt
Factory JCW Talk (2009+)
Mar 14, 2016 08:50 AM
praecurvo
Jun 9, 2013 09:33 PM
k_h_d
Aug 27, 2012 05:08 PM
