Engine noise? Please HELP
Old Feb 10, 2020 | 08:38 AM
alconk's Avatar
alconk
I own two R53 and my brother just bought a R56 with known problems. Turns out has a burnt valve so I removed everything down to the block and sent the head in for machining. Got it back and everything is back installed. I decided to start it to make sure it would without coolant and it did and ran it for about 30 seconds. I was about to turn it off when it started to sound like a Diesel engine. I’m worried since I didn’t have any coolant in there that something got hot. Please help!! This R56 I will tell you much more complicated than my R53.
Old Feb 10, 2020 | 08:41 AM
DneprDave's Avatar
DneprDave
Try putting coolant in it and run it again.
Old Feb 10, 2020 | 09:10 AM
alconk's Avatar
alconk
I did same noise
Old Feb 10, 2020 | 10:32 AM
giorgos's Avatar
giorgos
Could you upload a soundfile or a video?
Old Feb 10, 2020 | 11:01 AM
alconk's Avatar
alconk
Unable to upload buts its coming from the valve train. Sounds like there is no oil lubricanting the rockers. I pulled the valve cover back off and looks fine. What am I missing? where does the head gets it’s oil from port wise? I would like to crank it over and see if I can see oil coming up. Since I had the oil filter housing off to replace the seals would it be air bound ? I have no idea just thinking out loud. It’s definitely coming from the valve cover area
Old Feb 10, 2020 | 01:05 PM
alconk's Avatar
alconk
something to do with Administrator not allowing to upload videos or pictures??
Old Feb 10, 2020 | 03:14 PM
giorgos's Avatar
giorgos
You need to click on "Go Advanced" (not "Post Quick Reply"). There you can add attachments.
Old Feb 13, 2020 | 12:00 AM
alconk's Avatar
alconk
Well for a update I was told the noise was lifted noise and needed to rev the engine to 2500 or so to build oil pressure to pump up the lifters. So I did that and the noise started to go away then heard mechanical crashing noises. Took the valve cover off and the exhaust sprocket bolt broke and was laying in the chain cavity. Just got the head back off and every exhaust valve is bent and all four pistons have valve impressions. Obviously the valves need replacing but are the pistons ok like that
preme123
Jan 21, 2013 07:15 AM
MiniKJ
Sep 11, 2008 09:18 PM
mikesminicooper
Aug 1, 2008 07:24 AM
mikesminicooper
Jul 30, 2008 10:49 PM
MiniMusician
Feb 16, 2007 01:21 PM
