R50/53 Need a 6 spd clutch alignment tool
Old Feb 9, 2020 | 08:27 AM
Cruztpirate's Avatar
Cruztpirate
Anyone have one I can borrow? I’m in Tampa but would pay you shipping. Cheaper than the $50 bs on eBay. Or if someone can just point me in the direction of a basic plastic tool like what comes in a clutch kit
Old Feb 9, 2020 | 11:58 AM
cooper48's Avatar
cooper48
Easy solution -- you don't need it. Clutch alignment tools normally are for syncing the clutch disk, pilot bearing and input shaft. Your Mini doesn't have a pilot bearing. Only the clutch disk and input shaft have to be aligned (teeth) and the tool doesn't actually help do that (note that there are no teeth on the tool). Once the new clutch is installed, turn the crankshaft slowly as you push the transmission toward the block and the disk will align with the input shaft and slip on.
Old Feb 9, 2020 | 12:39 PM
1qwkmini's Avatar
1qwkmini
Good luck mating the transmission to the engine block if the disc isn't centered on the crank.
Old Feb 9, 2020 | 01:32 PM
cooper48's Avatar
cooper48
That's my point. The tool does nothing to center it.
Old Feb 9, 2020 | 02:03 PM
1qwkmini's Avatar
1qwkmini
Then I guess you have the wrong tool!!
Old Feb 9, 2020 | 02:10 PM
BRGPA's Avatar
BRGPA
I just helped a friend install a clutch on an old Porsche 914. We used the classic broomstick sharpened a little to make the alignment and the trans went in like butta!
Old Feb 11, 2020 | 11:24 AM
Soul Coughing's Avatar
Soul Coughing
I held the clutch disc center with my finger while i had my other hand on the wrench and tightened one of the pressure plate bolts. That locked it in the center of the pressure plate and made the marriage with the transmission a lot easier!
Old Feb 13, 2020 | 02:02 PM
David Baker's Avatar
David Baker
On the MINI clutches I've done, the clutch disc and pressure plate friction surface are almost identical in size. When I put the pressure plate on, I thread the bolts in by hand, then feeling around the perimeter of the clutch plate to make sure it is inline with the pressure plate. Every time I've done that, the transmission lines right up and slides home.
Old Feb 14, 2020 | 05:29 AM
astroBlackMetallic_Mini's Avatar
this may work...
https://www.thingiverse.com/thing:1257114
i can print and send you one for $20.
youd just have to check if its the same for a R53... let me know
njaremka
Sep 26, 2019 02:12 PM
tag1260
Dec 12, 2017 12:42 PM
monkeyb0y
Apr 4, 2014 09:25 AM
Carmichael
Chicago MINI Motoring Club
May 16, 2012 02:52 PM
R35P3CT DA M1N1
Nov 1, 2010 08:21 PM
