JCW big brake kit.
Old Jan 27, 2020 | 10:39 AM
Bezlar's Avatar
Bezlar
JCW big brake kit.
Getting ready to install these and wondering which side to start when bleeding. Each brembo caliper has 2 bleed points, inside and outside.
thanks
Old Jan 27, 2020 | 05:43 PM
Bezlar's Avatar
Bezlar
well started tonight. Took about 2 hours on the front left. Front right should only take about 1 hour tomorrow after I have figured out what tools I needed. Prod do one rear tomorrow after the other front. So far so good. I’ve never bled brakes before so that should be fun when all done installing. I bought a power bleeder. Looks easy enough.
Old Jan 28, 2020 | 01:02 PM
Bezlar's Avatar
Bezlar
Did the other front today. Took right around an hour. That was jacking car up and taking wheel off and back on when done. Makes the neuspeed wheels look much better. Not a lot of room between the caliper and wheel. Bit more than a quarter. I guess that’s enough. Wheels said the cleared the JCW brakes.
Old Jan 28, 2020 | 02:59 PM
MikeMJCW's Avatar
MikeMJCW
FYI: My factory wheels/brake only have 5mm caliper/wheel clearance, less than 1/4 inch.
Old Jan 28, 2020 | 08:22 PM
minicooperjp's Avatar
minicooperjp
Looking real good! I am wanting to do this retrofit, if you don't mind me asking, about how much was the kit for you?
Old Jan 28, 2020 | 08:23 PM
Bezlar's Avatar
Bezlar
Thanks. Makes me feel better.
Old Jan 28, 2020 | 08:24 PM
Bezlar's Avatar
Bezlar
$1431 shipped.
Old Jan 29, 2020 | 06:44 PM
Bezlar's Avatar
Bezlar
Well finished the rears and bleed the brakes once. I have a spongy pedal. I can pump it up and it holds but as soon as I release it spongy again. I’m going to re bleed tomorrow. Mybe try the old fashioned way. Any suggestions would be great.
Old Jan 29, 2020 | 06:45 PM
Bezlar's Avatar
Bezlar
Old Jan 30, 2020 | 04:12 AM
Bezlar's Avatar
Bezlar
Ok so after I couldn’t sleep I got up at 4 and re bled the brakes. I did the brembos inside out. Everything is good now. Took it out at 5 to bed in the pads. People prob thought I was crazy with the stop and gos. This was the first time I’ve ever tore brakes down and installed new. Done pads before but never cracked open a bleeder valve. I’ve always been intimidated by brakes. No longer. That was pretty easy and the power bleeder works great.
Old Jan 30, 2020 | 10:12 AM
Juice84's Avatar
Juice84
is there any reprogramming required with the BBK?
Old Jan 30, 2020 | 03:38 PM
Bezlar's Avatar
Bezlar
supposed to but I’m not going to. I’ve heard they program whole car and I’ve got new retrofitted 8.8 touch screen with wireless CarPlay. I’m not going to give dealer chance to screw up my coding. A lot of people have installed and not gotten the update. Drives fine.
Old Jan 31, 2020 | 04:50 AM
Bezlar's Avatar
Bezlar
Old Jan 31, 2020 | 10:06 AM
Juice84's Avatar
Juice84
Are the rears much larger than the standard rears? They don't look it from your pictures but you also have larger wheels...
Old Jan 31, 2020 | 11:38 AM
Sweet! Those look soo good and i bet the braking is much better
Old Feb 1, 2020 | 04:15 AM
Chief Brody's Avatar
Chief Brody
No, the rears are exactly the same just red.
Old Feb 1, 2020 | 08:29 AM
Bezlar's Avatar
Bezlar
Yes just red. I tried to get just the fronts but is was cheaper just to get the whole kit.
thanks
Old Feb 1, 2020 | 04:14 PM
rAte's Avatar
rAte
looking GOOD!
Old Feb 1, 2020 | 05:13 PM
J_L's Avatar
J_L
Very nice!
How does it feel and brake compared to stock? Stiffer pedal? Easier to modulate? Stops harder?
Old Feb 3, 2020 | 12:12 PM
6FT6's Avatar
6FT6
Originally Posted by J_L
Very nice!
It's def more stopping power.
When I first had it installed I didn't code it and it seemed a bit "sensitive" not very smooth when stopping.
I coded it myself and it smoothed out the braking, they "say" without coding the rotors wear unevenly.
N.B I'm a paraplegic so I am modulating the brakes with my hand and thus may find it much more aggressive. Took me a bit to adjust from the stock setup.
Old Feb 3, 2020 | 12:43 PM
Bezlar's Avatar
Bezlar
how did you code yourself?
thanks
Old Feb 3, 2020 | 01:24 PM
6FT6's Avatar
6FT6
thanks
Using E-sys, added it to the VO/FA and changed the rotor size.
Open your FA in FA-Editor, expand it. Go to Type. Right click Ho-Wort and select add. type SPOB.
You go back to Expert/Coding, load the FA you just edited, select DSC ecu and VO code it.
In DSC search disc. The disc size of JCW for front is 335x30 and rear is 300x20.
Thats it.
We have a Q7 and when I drove that before coding the JCW brakes I said to myself “I gotta code those brakes, they feel like **** compared to this”
Old Feb 3, 2020 | 01:52 PM
6FT6's Avatar
6FT6
Man that’s close .
I was wondering why your name looked familiar, we “met” in the Navigation and Audio forum.
Old Feb 4, 2020 | 04:47 PM
Bezlar's Avatar
Bezlar
Lol. Yep. I have an rs3 and a sq5 also and find the brakes to feel somewhat the same. So you think that’s all they change on the code is the diameter of the rotor? I read that it was supposed to change the clamping force? This is my daughters car so I didn’t want to make anything unsafe. I figured with just the fronts being different that coding it really can’t make that much of a difference. I’m new to the bmw coding. I’m used to vag. Thanks for your help. This was the photo that made me want the JCW brakes for her car.
Old Feb 4, 2020 | 04:54 PM
Bezlar's Avatar
Bezlar
much better now. Lol
