R56 EDIABAS Help
Old Jan 14, 2020 | 04:54 PM
wajulia's Avatar
wajulia
EDIABAS Help
I realize there are lots of threads on this and i hate to start another. But is there someone who can help me. I installed it in my windows 10 computer following the installation instructions meticulously.
. When i start the INPA app i get the following error message . Any help would be appreciated!
Old Jan 15, 2020 | 09:33 AM
MiniToBe's Avatar
MiniToBe
it's been a loooong time since I saw this error. But, you might have navigate a file with ediabas.ini or inpa.ini or obd.ini in the BIN folder. Once you locate and open it, make sure the com is set to right one (should be COM1) and obd is called out, not Ethernet or something else. sorry if that adds to the confusion, but it is start
Old Jan 15, 2020 | 04:18 PM
wajulia's Avatar
wajulia
Thank you SO much. That allowed me to start the INPA application. I got the "Battery" and "Ignition" bubbles to fill in. BUT -- I just got the error below. I am trying to connect to an R56 (2008 turbo hatchback). The group file changes with my different selections, but the error is the same. ANY HELP VERY APPRECIATED!!!!!
Old Jan 15, 2020 | 05:00 PM
MiniToBe's Avatar
MiniToBe
Are you selecting the user information field on the right or your selecting the engine module directly?
Old Jan 16, 2020 | 04:20 PM
wajulia's Avatar
wajulia
Thank you again. shown below is how I select a function
first I select shift f3
then I select any function. Get the same error for any slection
Old Jan 16, 2020 | 04:48 PM
MiniToBe's Avatar
MiniToBe
Even when you just select "functional jobs" on the right side?
Old Jan 17, 2020 | 07:47 AM
wajulia's Avatar
wajulia
Again let me thank you so much for your help.
I used the functional jobs and got different results.
I got the following error code. - I said yes a number of times and finally moved on the main menu -- see below
Main menu screen below -- I selected any of those and got the screen with the error shown below. EXCEPT for one -- when I asked for "VEHICLE DATA" I got the right data -- see further below
When I select any of the options (Except the Vehicle Data) I get
See the SYS-005: Object file not found error. Got it for everything
I DID get the Vehicle information
Old Jan 17, 2020 | 12:09 PM
MiniToBe's Avatar
MiniToBe
Did you make sure if you go to the K+dcan usb properties that the latency is set to 1 NOT 16?
Also, you might be missing files that read the modules. we could do a Teamview and go over your files. in the mean time, see if there is anything on youtube that goes through setting up INPA (to start with).
Old Jan 18, 2020 | 10:18 AM
wajulia's Avatar
wajulia
the latency is set to 1.
I will look on you tube, but I haven't found anything yet. the error feels like I dont have the files I need, but I have no idea which files they are
Camilo A Londono
Oct 31, 2015 03:00 PM
texasmontego
Electrical
Jun 22, 2013 10:09 PM
morterror
Dec 16, 2009 12:05 PM
oldtrojan66
May 22, 2007 08:46 PM
AC_MINI
Oct 5, 2003 12:45 AM
