R55 2011 climate control in '08 console?
Old Jan 8, 2020 | 06:16 PM
Brady Meyer's Avatar
Brady Meyer
Howdy guys.
Can I put the manual climate control unit from a 2011 mini into my 2008 clubman S john cooper works?
I hate the look and functionality of the stock unit, and 2ould love some good old fashioned buttons and upgraded appearance.
I'm capable enough with wiring, so if I would need spliced a little that wouldn't be a problem for me.
Any advice is appreciated,
Thanks!
Old Jan 9, 2020 | 09:19 AM
MiniToBe's Avatar
MiniToBe
You could swap the shells. I did that on my 08 clubmnan s with automatic climate unit. Otherwise, check newtis.info for wiring and connections.
Old Jan 9, 2020 | 10:43 AM
Brady Meyer
If I just pull them apart and change the shells, will it replace the buttons and everything? Because my main complaint is the temp control "wheels" that you spin and the dial for coverage selection.
Old Jan 9, 2020 | 11:09 AM
MiniToBe's Avatar
MiniToBe
Not sure if it'll work. Manual to automatic controller requires coding too. Check the wiring in the links sent earlier to determine what needs to be done. I know there is also a sensor for the automatic climate that needs to be added.
Old Jan 14, 2020 | 07:54 AM
Manual to manual i think is fine and auto to auto. But not sure on the othere, like MINItobe stated its maybe coding and hacking into things.
https://www.northamericanmotoring.co...to-08-mcs.html
FromTexasinColorado
May 12, 2019 07:24 AM
tobey1kenobi
Dec 18, 2009 05:49 AM
HDClown
Mar 28, 2008 06:09 AM
MisterDangerPants
Feb 5, 2007 09:31 AM
