R56 Radio Is dead - 2013 hatch
Old Jan 1, 2020 | 02:05 PM
2cati's Avatar
2cati
My daughter advised me that the radio was acting strange when she took it to the gas station. The radio came on but she was unable to change the volume or change stations. On her way to the gas station the screen went back. Once she arrived at the gas station, she turned he car off but the radio was still playing. She filled up/ paid for the gas and the readily was off - no sound. She started the car is and the radio now won’t turn on.
I did some searching and it seems these Radios have a high failure rate.
The car recently had the FRM recall work completed at a mini dealership but from what I read that shouldn’t impact the radio. The battery was replaced by the mini dealer a year ago so it’s definitely not the battery. The climate control and everything else seems to be functioning.
The fuses in the footwell are fine. I haven’t checked the fuse behind the radio (I read a post there is one on the back of the radio). There is no moisture in the foot wells and my sunroof drains are not plugged.
Before I rip the dash apart, is there any known issues with the wiring or harnesses that would cause this problem? Ant other pointers?
Also, if the radio is dead and I find one from a local wrecker, will it be plug and play or will some form of reprogramming be required?
Any suggestions would be appreciated!
Old Jan 2, 2020 | 10:29 AM
Yupetc's Avatar
Yupetc
You probably best to pull that radio out and check the fuse behind the radio first. If the fuse is still good, and with all the other checks you've done, then yes, it's a failed radio and you'll need to replace it. These radios have a high failure rate. I've gone through four 2nd gen mini's so far, and one of them has a bad radio after 2 years of use.
Old Jan 2, 2020 | 11:59 AM
2cati's Avatar
2cati
Thanks, I’ll wait for warmer weather before is tackle removing it to check the fuse. I just feel the way it failed gradually doesn’t seem like an issue with a fuse going.
Ill scan the local ads for a radio from a mini being parted. Does anyone know if the radio needs to be programmed or is it plug and play?
Old Jan 2, 2020 | 12:47 PM
Minnie.the.Moocher's Avatar
Minnie.the.Moocher
https://www.newtis.info/tisv2/a/en/r...hanger/IHXnWeg
Old Jan 2, 2020 | 01:54 PM
Yupetc's Avatar
Yupetc
Use Realoem.com and put your VIN in there, then perform the part search through those simple to follow diagram finders. Once you come across the exact part number matching what your radio should be, just plug it on eBay and buy it there, it'll be cheap and convenient. I got mine for $85 doing it this way. If you can't come across that part, then go to car-parts.com and navigate your way into their junky database and find the junkyard dealer's posting. I'm quite sure you'll come across one. Price varies.
Old Jan 3, 2020 | 01:11 PM
2cati's Avatar
2cati
Thank you everyone for your posts.
Thats a great way to find a plug and play radio! Thank you.
Well, well, well, my daughter updated me the Radio is mysteriously working perfectly again - it came on when she started the car - full display and fully functioning.....
These minis are a nightmare.
There must be some corrosion somewhere or cold solder joints - I may take a look in the summer time permitting.
I’ll continue to update this thread with developments.
veevsato
Aug 5, 2015 04:42 AM
NickChuck
23
Jul 18, 2012 12:48 PM
dawgscj7
Electrical
Mar 7, 2012 09:07 PM
Eric5279
15
Aug 17, 2011 07:57 PM
