R55 Help Please! Mini wont start
Old Dec 13, 2019 | 03:30 AM
tomsws6's Avatar
tomsws6
Ok, this morning I decided to add a little bit of oil to the car just as a safety measure. Its been sitting for 2 days and I know it leaks a little bit of oil so... Anyway i started it up and drove to the end of the drive(500ft or so) and popped the hood and shut it off while I added a little oil. I put cap back on and shut the hood and now it wont start! It was just running 2 minutes prior! You can hear it try just as if you would normally push the start button but it just keeps doing that. I went back and tried starting it multiple times but I got the same situation. Help please, anyone have any ideas?? ITs a 09 S clubman
Old Dec 13, 2019 | 05:10 AM
MiniToBe's Avatar
MiniToBe
It could be one of these things:
HPFP
engine somehow flooded with fuel
fuse box
ground wire on the valve cover is loose
Old Dec 13, 2019 | 07:10 AM
Fly'n Brick's Avatar
Fly'n Brick
How old is the battery? (A rhetorical question)
Old Dec 13, 2019 | 07:55 AM
tomsws6's Avatar
tomsws6
That Im not to sure of but didnt think to much of that since I just started it cold at 430am and shut it off 3 minutes later then immediately tried to start it again.
Old Dec 13, 2019 | 07:56 AM
tomsws6's Avatar
tomsws6
Originally Posted by minitobe
it could be one of these things:
Hpfp
fuse box
hpfp?
Old Dec 13, 2019 | 08:03 AM
MiniToBe's Avatar
MiniToBe
high pressure fuel pump
Old Dec 13, 2019 | 09:06 PM
Fly'n Brick
Take a look anyway. Just 4 weeks ago we started just fine for a 2 hour trip. 30 minutes in we stopped at a rail crossing so I shut it down till it passed. Gates went up but no start. What I remembered a 4 year old battery was actually seven, dead as a doornail. A nice guy got me jump started so we made the trip.
Old Dec 14, 2019 | 11:42 AM
tomsws6's Avatar
tomsws6
Gotcha! Weirdest thing, got home around 5 pm from work and for the hell of it tried to start it and after sitting for 10 hrs it started right up! WTH???
Old Dec 27, 2019 | 06:31 PM
R55 Clubs's Avatar
R55 Clubs
Makes sense to me. With a weak battery, and cold temps, you can get one good start. Normally youd be driving somewhere allowing the alternator to put a charge back into the battery. However, your battery is weak and only had enough charge to start the car once. Batteries will bounce back a little if you let them sit, and if they get warmer.
Not surprised it started when you got home.
Change or charge the battery. Verify the alternator output is approx 14.4 volts. These cars are sensitive to batter conditions.
Scrapperjill
Feb 26, 2013 09:34 AM
convict1
Apr 6, 2011 03:50 PM
luvlee
May 7, 2009 08:06 AM
luvlee
May 4, 2009 02:00 AM
luvlee
May 3, 2009 04:11 PM
