R50/53 Bad alternator bearing? Or waterpump
Old Nov 25, 2019 | 03:29 PM
theDonVon's Avatar
theDonVon
https://youtu.be/2ZP7K9oGRcw
I had a bad squeal so I replaced the belt and that sound went away and now I'm left with this chatter/ bearing noise can it be my alternator bearings or waterpump or even the tensioner maybe? I'm in desperate need of help thanks I highly appreciate it
Old Nov 25, 2019 | 07:06 PM
RockC's Avatar
RockC
No experience with my MINI JCW but with other cars I removed the belt -- be sure to note its routing and direction of rotation so you can install it just like it was before you removed it -- and gave each accessory drive pulley a wiggle test for play. My experience is the accessory drive with any play -- and it happened to be the water pump -- was the noisy one.
In this case I could feel and see the edge of the belt was rubbing -- it was a serpentine belt -- and that arises from the belt not tracking true and that arises from a drive with play that lets the pulley get pulled out of its correct alignment.
If accessory drive uses a V-belt a sign the belt is not tracking properly can be pulley wall that shows some kind of wear pattern that doesn't match the other wall. Hard to describe but I know it when I see it. The one side is doing most of the work.
Old Nov 26, 2019 | 09:29 PM
BlwnAway's Avatar
BlwnAway
Most likely tensioner, just to check, get yourself an automotive stethoscope to pinpoint the noise.
Amiee
Jan 31, 2019 11:30 AM
jglover
Aug 3, 2018 01:00 PM
nshannon29
Oct 7, 2015 05:57 AM
Minicoopr50
Feb 26, 2012 08:08 AM
TUFFMINI
Jan 25, 2006 03:02 PM
