Fog lamp error w/exclamation when you don’t have fog lamps ?
Old Nov 20, 2019 | 03:55 PM
ZRXChris's Avatar
ZRXChris
So I have no fog lamps on my 2010 Clubman
then what does this error mean
Old Nov 20, 2019 | 04:29 PM
AZdsrt's Avatar
AZdsrt
I can't answer your question, but do you really have 100k miles on a 2020?
Old Nov 20, 2019 | 04:55 PM
ZRXChris's Avatar
ZRXChris
no, I can’t type...2010
Old Nov 20, 2019 | 06:33 PM
ZRXChris's Avatar
ZRXChris
Found it!
but I seems like my
low beam works fine?
Old Nov 21, 2019 | 09:05 AM
Low beam might be going on/off, if you have halogen bulbs, my guess ifs the element is on/off.
Old Nov 21, 2019 | 03:21 PM
MVPeters's Avatar
MVPeters
LED bulbs may affect the bulb check & cause this light.
Old Nov 21, 2019 | 07:30 PM
ZRXChris's Avatar
ZRXChris
stock bulbs, gonna check the connections and see if one is loose. 100K, maybe the computer is smart and knows when one is about to go out?
Old Nov 22, 2019 | 05:25 AM
jwzimm's Avatar
jwzimm
The checks are performed by measuring resistance in the circuit to the bulb. If the resistance is out of the specified range, it determines there is a fault and lets you know. Smart system actually. That is why LED's cause errors as they present a different resistance value. It is also why replacing halogens with LED cause the flickering lights on startup. The resistance check is performed by passing a brief voltage to the circuit to measure resistance. A halogen bulb would not illuminate since it is such a brief pulse but the LED requires next to no time to illuminate so they do.
In any case, the car should be able to tell you exactly which bulb it is detecting an issue with in check control.
Old Nov 26, 2019 | 08:32 AM
ZRXChris's Avatar
ZRXChris
when I go into check control it just says check ok, can’t see the error code.
Old Nov 26, 2019 | 08:37 AM
jwzimm's Avatar
jwzimm
Weird, not sure what's going on then.
Old Nov 26, 2019 | 09:19 AM
ZRXChris's Avatar
ZRXChris
came across this the other day, basically says that the computer has to be reprogrammed to remove the fault. Guess I just have to pay attention to my headlamps to ensure they are working.
  • TSB SIM630110:Check Control Message but Lights are Operating Normally
Old Nov 27, 2019 | 03:25 PM
ZRXChris's Avatar
ZRXChris
No luck
Local BMW mechanic says he can’t find anything wrong with any of my lights and says it might be that the footwell module is going bad.
best he could say is to do a period safety check to make sure my headlamps work.
bummer
Old Dec 14, 2019 | 09:02 AM
RockyR's Avatar
RockyR
Odd things can happen if your battery is low or going bad. Computers don't like low voltage.
Old Dec 19, 2019 | 03:42 AM
TJANK's Avatar
TJANK
Just a thought. I know in the US the rear fog light require a switch and coding. That said, there is still a bulb for the rear fog light (must be cheaper to manufacturer by just adding it). I would check that rear fog bulb to see if it is bad.
Old Dec 19, 2019 | 06:11 AM
ZRXChris's Avatar
ZRXChris
thanks! ill try that
also Bimmercode is throwing a few faults that aren’t triggering CEL warnings yet
d@g
Jun 9, 2017 06:30 AM
Bkreezel
Apr 29, 2015 06:26 PM
ghamma
20
Oct 30, 2011 10:38 PM
walty
R55 :: Clubman Talk (2008+)
Jun 30, 2008 06:54 AM
matma92ser
May 19, 2006 09:08 PM
