R58 Oil pump solenoid repair kit
Old Nov 16, 2019 | 11:27 PM
Mini2018's Avatar
Mini2018
I have an 2012 Coupe S. It was recently in the shop for something unrelated and the dealer indicated my oil solenoid was leaking. Taken back by the cost i ordered the repair kit that, see link below:
https://www.ecstuning.com/b-genuine-...e/11418609973/
Question / Issue:
I cannot get the old solenoid out of the side of the block. It was supper tight to start with and too forever to disconnect and remove to cap. Based on the doc provided with the part it should pull out and i'm supposed to disconnect and reconnect with the replacement part. Has anyone remove this part and if so how did you do it. I'm starting to suspect, i need to remove my passengers side CV shaft to get better access, but not sure
Any advice would be great
Old Nov 16, 2019 | 11:41 PM
Mini2018's Avatar
Mini2018
Update:
Bit confused by minis instructions (see below)
Am i supposed to pull the existing solenoid wire out of the block until i find the mid point connection and then attach this repair kit, or am i supposed to disconnect the existing connection that is currently external and cliped to the side of the block and connect this repair kit. Then feed the additional cable length into the side of the block using the tool.
http://australiancar.reviews/_pdfs/T...-12_201401.pdf
Update:
Old Nov 18, 2019 | 08:11 AM
Hello,
This is the thread about that sensor, did you see this: https://www.northamericanmotoring.co...noid-leak.html
MeBoosta
Jan 20, 2013 03:29 PM
p8ntbollr
Oct 26, 2012 11:51 AM
Hillis24
Sep 19, 2011 11:54 PM
works8
May 24, 2008 07:08 AM
