R50/53 Wont start after supercharger/ignition switch replacement
Old Nov 8, 2019 | 12:57 PM
Gutling's Avatar
Gutling
2004 r53
I have had the mini taken apart few weeks now while waiting on parts, and finally got it mostly back together. It was cranking/starting fine before this.
Will the mini start without the front clip on? I was wanting to start it and check for leaks before putting it 100% back together, but when I turn the key nothing happens. Lights/dash all good and bright, no check engine lights. It doesnt do anything when I turn they key, no starter action.
Now besides replacing the supercharger, I also replaced the ignition switch on the interior. So this problem could very well be the ignition switch. It is a new one, not used. I was having trouble with constant key in door chime and thought replacing the ignition switch would help.
So, to summarize.. will the mini start without front clip installed? And, would a bad ignition switch cause a no start/crank, and is there a way to test/bypass it just to see?
Tests done/additional info:
Battery is good, tested good and I hooked a jumper to it to be sure. 14v and same thing.
I do hear fuel pump and everything prime when I turn key, and when I turn it to start I do hear a relay clicking under the steering wheel somewhere.
Old Nov 9, 2019 | 08:37 AM
Gutling's Avatar
Gutling
Fixed it. I dug down to the starter (which is terrible by the way) and wacked at it while someone was trying to start it, and got it to turn over. Its been sitting couple of weeks, and guess just got stuck from inaction
Old Nov 12, 2019 | 08:18 AM
robj's Avatar
robj
That's what I call a WPHB repair.
[Well Placed Hammer Blow...]
Good show!
robj
usafdrew
Nov 30, 2023 10:13 AM
Colin Schlagel
Sep 20, 2017 06:52 AM
2004minicooper
Apr 9, 2016 01:52 PM
2003minicooper
Sep 30, 2014 10:40 AM
2003minicooper
Nov 24, 2012 08:24 AM
