R50/53 Bargain Mini - Spline Question
Old Nov 1, 2019 | 07:02 AM
robj's Avatar
robj
With the engine pretty much buttoned up, on to the axles and suspension. I checked the ball joints and they were definitely loose, [1/16 up and down play on the outer] so all that's being replaced, along with new struts, strut bearing, pads, sway bar links, etc...
When removing the axles, I saw the splines had "rust dust", obviously a sign of wear. I couldn't feel any looseness but unless the spline is about to fail I doubt the wear can be felt. The bearing did feel smooth though.
Having come this far I ordered new wheel bearings and hub assemblies to go with the new axles.
The question is, should the splines be lubed [I assume they should be] but with what type of grease?
Thanks,
robj
Old Nov 1, 2019 | 12:17 PM
ssoliman's Avatar
ssoliman
I put / see people put anti seize grease on them all the time. They don’t “need” that to function but makes them easy to remove and keeps them from rusting as bad
Old Nov 1, 2019 | 09:57 PM
Redcap's Avatar
Redcap
Type doesn't really matter, but I use Bigfoot grease on hub/axle splines such as this. It is a water-resistant heavy equipment grease.
Lex2008
How to
11
Sep 7, 2017 10:19 AM
BoDarville
Oct 8, 2014 06:57 AM
cw40342
Jun 26, 2014 11:12 PM
Cjustice
Mar 8, 2014 09:37 PM
meb
Suspension
Jul 15, 2006 06:17 AM
