CV Axle
Old Jun 13, 2014 | 05:21 PM
cw40342's Avatar
cw40342
CV Axle
Ok so here is my question.
Has anyone found a way to use the clamps that come in a boot kit without having to buy the specialty tool to tighten it?
Question two
I went to replace the inner boot and when I took the bearing out I dropped them and well they are bearings no more. So I bought a new axle should I replace the whole thing or just the half shaft?
Old Jun 13, 2014 | 06:58 PM
cw40342's Avatar
cw40342
What do you do when you can not get the part of the shaft that goes into the transmission out?
Old Jun 13, 2014 | 08:04 PM
thefarside's Avatar
thefarside
Question two
I'm confused - you bought a new axel or not? If you bought one why wouldn't you replace the entire axle?
Cleaning the bearings after dropping (I assume) in the dirt should not be that big a deal to clean.
Old Jun 13, 2014 | 08:05 PM
thefarside's Avatar
thefarside
Drive a pry bar between the transmission and axle.
Old Jun 14, 2014 | 01:42 AM
cw40342's Avatar
cw40342
Originally Posted by thefarside
I'm confused - you bought a new axel or not? If you bought one why wouldn't you replace the entire axle? Cleaning the bearings after dropping (I assume) in the dirt should not be that big a deal to clean.
Yes I bought a new axle but I was going to try to just leave the half shaft piece in the transmission in. An replace the outer only but I'm gonna have to do the whole axle so I answered my own question there.
My whole issue now is I can't we the inner axle out of the transmission!
cw40342's Avatar
cw40342
Tried that and nothing moved a little by that was it.
Old Jun 14, 2014 | 09:18 PM
cw40342's Avatar
cw40342
Does anyone know how I can hunt down the shaft support bracket for the CV axle on the right side?
Old Jun 26, 2014 | 10:54 PM
arth4's Avatar
arth4
This worked good for me to crimp:
Amazon Amazon
Old Jun 26, 2014 | 11:03 PM
arth4's Avatar
arth4
You might want to watch part of this, starting at 13:50:
Old Jun 26, 2014 | 11:06 PM
arth4's Avatar
arth4
or this one, starting at 22:10:
Old Jun 26, 2014 | 11:12 PM
arth4's Avatar
arth4
I think the braket you are looking for (if I understand) comes with the right-side output shaft: http://www.pelicanparts.com/catalog/...SUSAXL_pg1.htm
OutMotoring
Mar 3, 2017 06:29 AM
gknorr
Dec 26, 2016 09:38 AM
vulkandino
Oct 31, 2015 08:29 PM
gknorr
Oct 1, 2015 09:20 AM
gpwpat
Sep 15, 2015 11:58 AM
