Kazera pitting
Kazera pitting
I have Kazera KZ-R wheels that are under a year old and have 15k miles on them. I waxed the wheels before putting them on and wash them every couple of week. They have started pitting. Any suggestions on what to do and how to stop it getting any worse?
I wish I had thought of this as being a warranty issue earlier as I may be out of warranty. Here are pitcures from two different wheels:
http://www.sanibelsand.com/Wheel1.jpg
http://www.sanibelsand.com/Wheel2.jpg
Keith
Keith
The marks in the picture are not grime they are defects in the surface. I even used wheel cleaner and a tooth brush the thoroughly clean it. They are still there. Some of them have metal deposits that appear to have leached through the coating and chip off.
uh oh... I think you may have just voided your warranty...
Wheel cleaner
Tooth brush
(boar's hair tooth brush? nylon?)
Don't mean to sound like a preacher, but when cleaning wheels
just use regular car shampoo and sponge or boar's hair wheel brush.
Then polymer wax afterwards from time to time.
If only brake dust and unbaked,only driven in the dry, I use only
detailer spray and soft papertowel and polymer wax now and then.
Wheel cleaner
Tooth brush
(boar's hair tooth brush? nylon?)Don't mean to sound like a preacher, but when cleaning wheels
Alex
An update...
Alex called me and went through some possibilities. The marks could be solid deposits of break dust embedded in the surface. If not, he was committed to getting the problem solved. He suggested cleaning with wax and the edge of an old credit card to free the deposits and finish off with an old clay bar. It was a lot of work but now the wheels look great!
I am really impressed with this level of customer service and commitment to his products. I will definitely be a Tire Rack customer for life!
Thanks Alex
Thanks Alex
Bumping an old thread, I'm considering the Kazera wheels for my MCS. How have they held up in general?
It's probably either these or a set of Rotas. The Kazera seems to be borderline too good to be true in the price department.
I"ve got KZ-Vs...
Alex reccomended them when the SSR closeouts were out of stock... Anyway, they're pretty light (~16 lbs). They need hub-centric rings. The plastic ones that came with the wheels are OK, but I've found to get good centering I have to start at 40 ft-lbs on the torque wrench and go up in ~15 ft-lb increments. Even with that, sometimes I have to take one off and start all over to eliminate balence issues. I don't think this is a Kazara issue, but a plastic centering ring issue....
Cleaning is pretty easy except for where the split spoke gets to the rim. Takes a bit more effort there. I haven't had problems with finish or the like, but then I don't take care of my wheels the way others do.
Overall, I'm pretty happy. Metal rings would surely help, but I just haven't taken the time to find any. It's on the list of things to do....
Matt
ps, I'm running 17x7s
I've had my chrome 17" Kazera's for over a year now and they still look as they did when they were new. Keep them clean, a little wax now and then....love them. The only issue I've had, which TR took care of, right away and no charge, the plastic plugs that go into the un-used holes in the wheel would work themselves out after some "spirited" driving. I think the brakes would heat up, the plastic would soften and bye-bye plugs. Bigger brakes with better cooling, 5ea. 20min. track sessions at Laguna Seca on 12/14/05 and not one of the plugs came out.
Thanks for the feedback guys.
How'd TR "take care" of it? Were the plugs redesigned?
Question on centering rings..
Originally Posted by Alex@tirerack
New plugs on the house likely. Sounds like with the addion of his BBK and the better heat dissipation resolved the issue.
Alex
Alex
Matt
