Bent valve(s)?
Old Oct 14, 2019 | 10:48 AM
Ragingbull69's Avatar
Ragingbull69
Bent valve(s)?
New to the mini life (daughters car). 2007 Cooper S. On her way home from college, check engine light began flashing and the car was 'shaking'.
For her towed home and I started checking out the car. Engine codes showed misfire on cylinders 2,3,&4. She had said the CEL had came on in the past, but hadn't stayed on. I pulled and replaced all 4 coils and plugs(no visible damage to plugs).
Started engine, same running condition(misfiring).
Checked compression and found #1=135 #2=0 #3=145 #4=140
I took valve cover off and timing chain 'looks' okay.
Going to get #2 into tdc and do a leakdown to determine where i'm losing the cylinder pressure.
Am I headed in the right direction so far?
Does this sound like i'm looking at a bent valve, due to a jumped timing chain?
Thanks in advance for any help. 👍🏾
Old Oct 18, 2019 | 07:00 AM
David Baker's Avatar
David Baker
If I had to offer a suggestion, bent valve, most likely not. Burnt valve, very possible. Since you have 0 compression on that cylinder, it is possible the valve is missing a chunk out of it.
TacoEngineer
Jun 17, 2020 03:18 AM
texasmontego
Sep 23, 2019 05:47 AM
SWAgoat
R55 :: Clubman Talk (2008+)
Jan 20, 2017 08:51 AM
Blacked Out 2010
R57 :: Cabrio Talk (2009+)
Oct 29, 2015 06:00 AM
csmitty
Apr 10, 2015 07:14 PM
