R50/53 Broken headlight washer
Old Oct 9, 2019 | 02:13 PM
speedman's Avatar
speedman
Does anyone know if I can repair the broken tip on one of my headlight washers. The part that mounts to the washer door has broken off. It looks like it could be repaired
Old Oct 9, 2019 | 03:52 PM
shrevemini's Avatar
shrevemini
Top Answer: 1
Can't have to replace washer pump
Which side did you break?
Old Oct 9, 2019 | 03:59 PM
speedman's Avatar
speedman
Drivers side
Old Oct 9, 2019 | 04:10 PM
shrevemini's Avatar
shrevemini
Top Answer: 1
Darn. I had an extra passenger. Would have sold cheap. I broken the driver side a few weeks ago when I swapped headlights. Order a new one
Old Oct 9, 2019 | 08:34 PM
kensic's Avatar
kensic
Any tip on removing the pump from the little door. It seems to always break that little latch when I tried. Tried 3 at a junkyard
Old Oct 9, 2019 | 08:36 PM
kensic's Avatar
kensic
what’s broken? I think we all have an idea from your description, but post a picture just to make sure so we know exactly what we’re dealing with
Old Oct 9, 2019 | 08:44 PM
shrevemini's Avatar
shrevemini
Top Answer: 1
I know what you are talking about. There is a couple ways.
First option is the first extend sprayer are then remove chrome cover. Next is to remove chrome ring from headlight. The you can remove sprayer without busting the tip off.
Second option is to extend sprayer an very carefully apply pressure to the clips on the tip.
Option one is the easiest way.
Old Oct 9, 2019 | 11:39 PM
kensic's Avatar
kensic
2nd option seems to alway break the clips.
1st option. so remove the window cover chrome piece from the black piece (which is attached to the pump)? then remove the big chrome, so that you can maneuver it around the black piece.?
when remove the big chrome ring, there's a huge change that you will at least break 1 of the 3 clips at the top. i tried removing 4 rings, always break 1 of 3 clips.
Old Oct 10, 2019 | 09:17 AM
speedman's Avatar
speedman
How much for your passenger side. Mine is broken at the connection of the headlight door and the washer arm
Old Oct 10, 2019 | 10:21 AM
shrevemini's Avatar
shrevemini
Top Answer: 1
Where are you located?
Old Oct 10, 2019 | 02:08 PM
More info here:
https://www.northamericanmotoring.co...ht-washer.html
Just be careful on extension by hand with the lip up when unclipping that chrome clip.
Old Oct 10, 2019 | 02:26 PM
speedman's Avatar
speedman
I am in Richmond VA
Old Oct 10, 2019 | 02:29 PM
speedman's Avatar
speedman
Old Oct 10, 2019 | 03:29 PM
speedman's Avatar
speedman
Old Oct 10, 2019 | 03:57 PM
shrevemini's Avatar
shrevemini
Top Answer: 1
Now that's a familiar site.
Old Oct 10, 2019 | 04:58 PM
speedman's Avatar
speedman
Are you close by
Old Oct 10, 2019 | 05:21 PM
shrevemini's Avatar
shrevemini
Top Answer: 1
I can ship to you for 25.00 shipped.
Send payment to my paypal
Prospec4825@yahoo.com
With address.
Maybe
Aug 23, 2017 06:54 AM
stt816
May 14, 2011 07:13 PM
danielo
Apr 23, 2008 06:33 AM
MGCMAN
Detailing 101
30
Jan 3, 2007 05:44 PM
