Retrieving Saved Starred Favorites
Old Oct 7, 2019 | 07:34 AM
The Snowman's Avatar
The Snowman
I recently purchased a 2019 F56 with the MINIConnect (not with CarPlay) and am having trouble retrieving stations that I saved as "starred" presets (press and hold the main setting ****, then choose the preset number to save as).
Setting the starred presets is in the manual, but how to get back to that listing, without an attempt to save a channel as a preset is not in the manual.
Old Oct 8, 2019 | 08:07 AM
The Snowman
Figured it out. It's actually Presets.
You press either the Menu button and select Media or push the Media button, or press the Mode button. There is a Presets option at the top of the list in each case.
Old Oct 8, 2019 | 11:08 AM
Warren2185's Avatar
Warren2185
I've been a little confused at those also. I wanted to be able to scroll just my favorite Sirius channels for example, but I gave up. Maybe I'll dig back into it.
Old Oct 11, 2019 | 08:04 AM
Fahfoofnik's Avatar
Fahfoofnik
What's frustrating is that with terrestrial radio, moving presets around/changing numbered preset positions is easy...and works the same way it did on the 2016 F56 base model/base radio I had then. With Sirius/XM though, you can't do this; can't move SXM presets to different numbered locations within the Presets menu. I find this highly frustrating, and hate spending the time I have inside my MINI deleting all my SXM favorites and then re-adding them to the numbered preset position I prefer.
I know there's no fix for this, it's just a PITA to have to discover a new channel/content I want fast access to as a preset, only to find I can't move it to, say Preset 5 if I want to. I have to delete whatever is stored as Preset 5 and move everything down manually. This is not fun.
Old Oct 17, 2019 | 06:43 AM
The Snowman
See my post above. I figured it out as presets. Once you select Presets as a mode, you can scroll through them. It treats them like a separate device, which is odd.
knew2mini
15
May 13, 2017 05:17 AM
AlphaQuad
Sep 26, 2016 03:58 PM
02fanatic
May 26, 2016 06:22 PM
JohnWB
Jul 29, 2014 08:10 AM
MotorMayhem
Apr 26, 2014 05:35 PM
