R50/53 R53 Engine lifting brackets?
Old Sep 22, 2019 | 06:06 PM
alconk's Avatar
alconk
I may be pulling the engine/trans and the Bentley manual calls for two lifting brackets but can’t find them anywhere. Any ideas?
Old Sep 22, 2019 | 06:41 PM
BlwnAway's Avatar
BlwnAway
Never used them, always connected a chain to one of the bolt holes from the top motor mount bracket (rear of engine) and one of the engine to transmission mating bolts. (Forward of the thermostat housing)
Old Sep 22, 2019 | 06:45 PM
alconk's Avatar
alconk
Oh ok well I need to change my rear main seal and think this would be easier than dropping the subframe.
Old Sep 23, 2019 | 02:39 PM
A383Wing's Avatar
A383Wing
probably easier to just drop the transmission ....then the seal is right behind the flywheel
Bryan
Old Sep 23, 2019 | 08:38 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
NO, just pull the subframe and trans. It can be done so much easier than pulling both the engine and trans.
Old Sep 24, 2019 | 09:29 AM
alconk's Avatar
alconk
Have you done it that way before? I don’t have the bar that goes across the shock towers to hold the engine up.
Old Sep 24, 2019 | 12:30 PM
JAB 67's Avatar
JAB 67
You need to read through the numerous DIYs on how to do this. And trust me, Way Motor Works has done this more often than most anyone on this forum.
Old Sep 25, 2019 | 09:53 AM
alconk's Avatar
alconk
Ok I will do you have a link by chance?
Old Sep 25, 2019 | 10:39 AM
A383Wing's Avatar
A383Wing
Just use a floor jack with a block of wood under the oil pan...you don't really need an engine bar
Bryan
Old Sep 25, 2019 | 11:09 AM
JAB 67's Avatar
JAB 67
Google '2002-2006 Mini Cooper S clutch replacement ModMini YouTube' and you will find a two-part video tutorial.
Old Sep 25, 2019 | 11:37 AM
WayMotorWorks
Vendor
Yes I've done hundreds of clutches. I just support the engine from underneath with a pole jack, nothing on top.
Old Sep 26, 2019 | 08:11 PM
ghostwrench's Avatar
ghostwrench
A friend of mine ran a 2x6 across the strut towers with a chain and lifting bracket on the engine when he pulled a trans. It was kind of sketch, but it worked.
got_mini?
Dec 4, 2015 07:34 PM
bowdown
Feb 4, 2014 09:55 AM
E_Swift
Nov 10, 2013 03:58 PM
GregW
Dec 3, 2010 06:44 PM
MINI_chili
Nov 28, 2008 01:51 PM
