R50/53 What is this tubing??
Old Aug 23, 2019 | 07:32 AM
Jlcart88's Avatar
Jlcart88
I'm putting a 2005 Cooper S back together after a head gasket/ valve job and it appears a plastic tubing that comes out from the firewall is broken. It looks like it connects to a valve on the passenger side front that has a hose going into the throttle body. Can anyone tell me what this is and where it goes? I appreciate any help I can get... Thanks!!
Old Aug 23, 2019 | 08:27 AM
Hello,
Its here:
https://www.northamericanmotoring.co...regulator.html
Diagram
Old Aug 23, 2019 | 10:06 AM
Jlcart88's Avatar
Jlcart88
Thanks for the quick reply. That thread was very helpful. I’m trying to figure out where that line attaches and also the one in the top of the circle that looks like it has a small tube in it, like the tube broke off somewhere. Thanks again for the help!
Old Aug 23, 2019 | 10:10 AM
Jlcart88's Avatar
Jlcart88
Here’s another pic of the tubing I’m asking about.
This is the line I’m asking about. It starts near the firewall and ends near that other line, which I also can’t figure where it goes!! I don’t see a place on that valve to put it! 😳
Old Aug 23, 2019 | 10:46 AM
Jlcart88's Avatar
Jlcart88
Okay. After some more research on this site I figured it out. It’s part of the fuel system purge and those lines connect to each other. I kinda thought so but memory lapses as you get older! 😂. Now I just need to figure out the piece that connects them together. Thanks again for the help!
Old Aug 23, 2019 | 04:25 PM
cooper48's Avatar
cooper48
Tubing solution
Old Aug 23, 2019 | 06:33 PM
Jlcart88's Avatar
Jlcart88
Thanks for the pic.. That helps... John
Old Aug 23, 2019 | 09:46 PM
thmpr464's Avatar
thmpr464
I would expect a evap code would be generated. Was this the case?
Old Aug 24, 2019 | 10:35 AM
Jlcart88's Avatar
Jlcart88
Not sure if a code was generated. My daughter was driving and a heater hose tee broke and drained the coolant. No compression so I had the head rebuilt and surfaced. Found the tubing when putting it back together. I thought they connected together and realized the fitting that connects them was broken. So I just need to find that fitting to reconnect them. Thanks for the help.
Old Aug 26, 2019 | 10:57 AM
Hello,
Its part of this main line from what it looks like. 16116756928
https://www.ecstuning.com/b-genuine-...e/16116756928/
Old Aug 26, 2019 | 12:37 PM
Jlcart88's Avatar
Jlcart88
Yes. I believe that’s the one. I just need to get a fitting to attach them back together now!! Thanks for the reply!!
Old Aug 27, 2019 | 10:42 AM
Welcome.
joedude99
Nov 13, 2006 12:20 PM
xcaligali
DC Metro MINIs (Archive)
83
Aug 30, 2006 05:19 AM
sweep77
Jul 11, 2006 01:37 AM
dominicminicoopers
Mar 21, 2006 10:02 PM
xcaligali
Aug 16, 2005 07:12 PM
