Upgrades??
Old Aug 22, 2019 | 07:50 AM
The_Chili_Texan's Avatar
The_Chili_Texan
Upgrades??
Hello guys
Two days after I got my 08 MCS it started making the “kazoo noise” after searching around I’m going to conclude that it’s the pressure converter ECS Tuning part# (ES#2804736)
my question is since I’m going to be fixing something I might as well upgrade whatever I’m fixing.
Is ECS Tuning part number ES#3184434
An upgrade for what I’m fixing? It’s a blowoff valve but it has what seems to be a similar part in the pictures. I emailed them a couple a days ago to find out with no answer so far, so figured I’d just ask and see if anyone has an knowledge of it.
thanks in advance guys!
Old Aug 22, 2019 | 12:38 PM
vetsvette's Avatar
vetsvette
Moderator
If you haven't heard back from ECS, call them. They are easy to deal with and can answer your questions.
Old Aug 22, 2019 | 01:12 PM
I think one of my guys is getting back to you now. He was talking to us about the "kazoo noise"
Old Aug 22, 2019 | 02:10 PM
The_Chili_Texan
Yup! I got an email a little while ago. I guess the part that makes the noise doesn’t really get “upgraded” it’s just something that gets replaced after it goes out.
Ill be placing my order for it after I get off work. Thanks for the response.
Old Aug 22, 2019 | 03:07 PM
MrGrumpy's Avatar
MrGrumpy
The kazoo noise typically comes from a bad pressure converter. It is not a blowoff or diverter valve. They are on 2 different areas of the engine.
The pressure converter controls the wastegate on the turbo by vacuum, and is located under the intake manifold.
The diverter valve is mounted on the turbocharger. It dumps the boost pressure.
The pressure converter isn’t really anything to upgrade. You certainly can upgrade your diverter to a Forge or a GFB DV+ or something. There are a lot of posts on here about using a blowoff valve instead of a diverter. Seems to be sort of hot or miss if it will work without giving you a CEL. I looks to me like it’s not successful more often than it is, but read some for yourself and make up your own mind about that.
Good luck
Edit: Ok I stand corrected. According to the product info on their website, ECS says that one will not cause a CEL.
Str8Grizzly
Mar 14, 2013 06:01 PM
Guest
Sep 21, 2007 08:41 PM
Number1
May 25, 2006 03:06 PM
nommaz
Cooper (non S)
15
Nov 17, 2002 01:00 PM
muncheboy
General Discussion
May 21, 2002 03:04 PM
