Time to service brakes - upgrade too?
Old Aug 21, 2019 | 06:25 PM
CachacoMCS's Avatar
CachacoMCS
Hi All. My 2012 MCS is showing signs (including Brake light with lift on) of rotor and brake pad wear. From the history of the car I understand these have not been changed ever (56k miles).
I don't want to break the bank but some upgrade would be nice, if possible. Aside from OEM pads and rotors, are there any plug and play upgrades that you'd recommend? My use is not track , rather highway for commute plus some spirited driving.
Appreciate any help.
Old Aug 21, 2019 | 08:28 PM
yesti's Avatar
yesti
Akebono pads are great, way less dust than oem. Flush the brake fluid with some fresh dot4 and you should be good to go. If you don't like the brake pads sensor warning strip the wire ends, twist together and tape out of the way of moving parts. Check pad wear at oil changes, tire rotations, etc...
Old Aug 21, 2019 | 09:06 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
go for the EBC reds as that is what I would put on your car if you came in our shop.
https://www.waymotorworks.com/ebc-re...rake-pads.html
And rotors if you need them too
https://www.waymotorworks.com/wmw-br...-cooper-s.html
this will be low dust and have great bite. I use this setup on my personal car.
Old Aug 22, 2019 | 07:11 AM
CachacoMCS's Avatar
CachacoMCS
Thanks Way, this is helpful. How do you compare WMW rotors vs. OEM aa it relates to feel, quality and life. Also, do I need to buy new sensors for all four corners?
thanks.
Old Aug 22, 2019 | 12:10 PM
WayMotorWorks
Vendor
thanks.
They are just as good if not better as they are what we use on every brake job we do and good enough to have our name on them so I can't recommend them more. But there is also nothing wrong with the OEM rotors except the price. Ours are also a high carbon rotor.
As for sensors you only need one front for the left front and one rear for the right rear as the car only has 2 sensors total.
Old Aug 22, 2019 | 02:18 PM
Capt_bj's Avatar
Capt_bj
WAY:
Gotta say man, I've recommended you to others after good experiences myself
and can not argue with a recommendation for EBC RED - I've used 'em for years on multiple MINI
but MUST ask about 'your rotors' ......
you had a company turn out a SPECIAL BATCH of rotors of your own spec's ....... ??????
or you are selling what???????
This one has vexed me for years ......
Old Aug 24, 2019 | 04:22 PM
Niteshooter's Avatar
Niteshooter
I'd say EBC reds as well.. Btw just tried opening your links and get a server dropped the connection error message.
PierreLeona
Apr 20, 2012 03:35 PM
minsane
Tires, Wheels, & Brakes
Dec 17, 2010 11:26 AM
Frank in Toledo
Detailing 101
Aug 16, 2008 05:57 AM
goaljnky
Off-Topic :: Autos
Oct 9, 2006 09:46 PM
Dice-gal
Apr 25, 2004 07:08 PM
