Lack of heat
Old Aug 18, 2019 | 09:18 PM
Island_Moose's Avatar
Island_Moose
Lack of heat
My 2002 MCS has disappointing heat output in the cabin, regardless of setting on the controls. I flushed the cooling system, and managed to put my hand on both the intake and output hoses to the heater core...both were hot. Is it possible that my temp selection control isn't working properly? How does that system work? I have the big factory manual if someone could give me a page reference. I thought I'd check this before pulling the heater core, and thinking 2 hot hoses meant water was flwoing through it.
I don't know how hot the air should be, but it's quite literally incapable of warming the cabin on a cold morning.
Old Aug 19, 2019 | 04:44 AM
MVPeters's Avatar
MVPeters
Perhaps not entirely obvious, but the fan must be on at least position 1 to get any kind of heating or cooling at all.
The heater core is always hot, so the air arriving in the car is regulated by the vent air flaps - perhaps that's where the problem is.
I do find the vent selector switch to be pretty vague - I can redirect air to the feet or dash or windshield but the various combinations don't seem very useful, although it deals with New England winters OK.
Do you have the manual or the automatic system?
Old Aug 19, 2019 | 11:40 AM
Island_Moose
Manual. The fan at high speed blows lukewarm air at best.
Old Aug 19, 2019 | 11:45 AM
Check the heater core, sometimes they can get clogged over the years.
https://www.northamericanmotoring.co...acement-2.html
Old Aug 19, 2019 | 02:07 PM
MVPeters's Avatar
MVPeters
If you've flushed the system & you think the heater core, not just the hoses, is getting hot, then the issue is with the air flaps. ECS's post refers to a disconnected linkage.
MINI heaters are also notoriously difficult to bleed the air out of.
Old Aug 19, 2019 | 03:54 PM
ItsmeWayne's Avatar
ItsmeWayne
It sounds like the blend door is stuck! It is used by BMW to add the correct amount of hot and cold air and when it does not move, it will do things like you are describing.
wpoff85
Dec 28, 2020 12:39 PM
sevin
Dec 14, 2015 11:01 AM
wedge
Apr 27, 2009 03:27 PM
4GAZM
Jan 30, 2009 11:01 AM
rc'S
Jun 6, 2007 04:21 AM
