A supposed LSD 6 speed...
Old Aug 13, 2019 | 10:13 AM
Alecmorrie's Avatar
Alecmorrie
I have a chance to buy a 6 speed tranny locally from a guy who was told it had LSD he never installed it so he’s not sure, was wondering if there’s anyway to tell from just looking at it? I figure either way a spare tranny would be worth the $100 price tag.
Old Aug 13, 2019 | 10:49 AM
cooper48's Avatar
cooper48
The LSD (limited slip differential) is not part of the transmission.
Old Aug 13, 2019 | 11:03 AM
Alecmorrie's Avatar
Alecmorrie
Yeah you’re right it’s part of the dif inside the transmission which was a stock option in 05-06
Old Aug 13, 2019 | 11:18 AM
cooper48's Avatar
cooper48
My bad - should have done more research. Uninstalled, you'll have to split the cases to be sure.
Old Aug 13, 2019 | 11:44 AM
Alecmorrie's Avatar
Alecmorrie
All good. Think I’m buying it either way for the price
Old Aug 13, 2019 | 12:32 PM
HaltCatchFire's Avatar
HaltCatchFire
There should be a part number sticker - gearboxes with factory LSD will end in TBKL while ones without will end in TBKE. This assumes it hasn't been cracked open prior.
Old Aug 13, 2019 | 02:24 PM
Alecmorrie's Avatar
Alecmorrie
That’s the only sticker I’ve seen on it... I ended up getting the tranny and a Meghan header for $75 so I think it was worth it even if this doesn’t work. Probably should’ve done a bit of research but oh well. Also anyone know if an 06 transmission will bolt on to an 02? (Probably a bit late for that question but I can usually make something work)
Old Aug 13, 2019 | 03:13 PM
cristo's Avatar
cristo
Alliance Member
BKD should be a pre facelift non LSD
(unless added after the fact)
Old Aug 13, 2019 | 03:53 PM
HaltCatchFire
Looks correct to me as well. Crack it open, see what goodies can be found inside!
Old Aug 13, 2019 | 04:15 PM
Alecmorrie's Avatar
Alecmorrie
Ahhhhh I knew this was way too cheap to be true. I figure the brand new header was worth twice what I paid for all this. Seemed like a decent guy though as far as craigslist goes. This weekend I shall crack it and see what’s going on in there. Didn’t really want to pull the tranny till the clutch needed to be done anyway so I have time to play with this one. At this point I can always go quaife and have time to build it.
Old Aug 13, 2019 | 04:24 PM
HaltCatchFire
You never know, could be an aftermarket already in it. For the money, it's a good gamble
xaurfang
Apr 27, 2020 08:02 AM
Black Forest
Dec 10, 2017 09:48 PM
poolemac
Oct 24, 2007 08:39 AM
minilites
Sep 23, 2004 09:16 AM
